Please help me with my PCIe MOBO questions.
Solved by 191x7,
7 hours ago, John55 said:So does a motherboard not effect my wifi speeds? Does the wifi card wiggling in the PCI slot weaken it or no? Because like I said, there is a tiny bit of wiggle.
A tiny bit of wiggle isn't significant since it doesn't happen unless you wiggle the card.
7 hours ago, John55 said:So I like the video you sent me, but here is a question: how can I tell if my router has these traffic shaping algorithm stuff? Like that CoDel?
If you can't find it in the router settings, it doesn't have it.
