23 minutes ago, name66 said:
Hello, i do have tripple fan Gainward Phoenix RTX 2080Ti GS and my temps during gaming are arround 80C with fan speed set to auto in afterburner. Are these temps ok ? No OC
My 1070ti during gaming without OC is usually 50-60C
How many fans do you have in your computer case?
https://linustechtips.com/topic/1091524-rtx-2080ti-temps/#findComment-12788504
2 minutes ago, name66 said:
2x 120mm on rad push/pull , 1x 120mm intake, 1x 120mm exhaust. Its Corsair Carbide Air 240 case
Wow, well the temps shouldn't be that high I don't think.
I haven't used a 2080ti so I'm not sure how it should perform.
Yea I don't know what could be the issue. Are the fans on your GPU spinning? (I know its dumb but that's all I can think of).
https://linustechtips.com/topic/1091524-rtx-2080ti-temps/#findComment-12788524
2080 tis are hot.
Have you turned up the power limit? That can create a silly amount of heat.
I have old Cooler Master cases that use several 200mm fans and have ventilation in the side panels instead of glass and my EVGA XC(2 fan) runs at 75c under load with the power limit at 100% and 82c with the power limit at 130%. With the power limit at 130% and a very slight overclock it is at 84c under load. It is also crazy loud.
My 3 fan, 3 slot FTW Ultra runs 10c cooler than the XC.  It is 74c under load and can maintain 2070mhz. So I had to pay a $300 premium to get a 2080 ti that has "normal" temperatures.
RIG#1 CPU: AMD, R 7 5800x3D| Motherboard: X570 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3200 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX500 2.5" 2TB | Monitor: ASUS ROG Swift PG42UQ
RIG#2 CPU: Intel i9 11900k | Motherboard: Z590 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 3600 | GPU: EVGA FTW3 ULTRA  RTX 3090 ti | PSU: EVGA 1300 G+ | Case: Lian Li O11 Dynamic EVO | Cooler: Noctua NH-D15 | SSD#1: SSD#1: Corsair MP600 1TB | SSD#2: Crucial MX300 2.5" 1TB | Monitor: LG 55" 4k C1 OLED TV
RIG#3 CPU: Intel i9 10900kf | Motherboard: Z490 AORUS Master | RAM: Corsair Vengeance RGB Pro 32GB DDR4 4000 | GPU: MSI Gaming X Trio 3090 | PSU: EVGA 1000 G+ | Case: Lian Li O11 Dynamic | Cooler: EK 360mm AIO | SSD#1: Crucial P1 1TB | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
RIG#4 CPU: Intel i9 13900k | Motherboard: AORUS Z790 Master | RAM: Corsair Dominator RGB 32GB DDR5 6200 | GPU: Zotac Amp Extreme 4090  | PSU: EVGA 1000 G+ | Case: Streacom BC1.1S | Cooler: EK 360mm AIO | SSD: Corsair MP600 1TB  | SSD#2: Crucial MX500 2.5" 1TB | Monitor: LG 55" 4k B9 OLED TV
https://linustechtips.com/topic/1091524-rtx-2080ti-temps/#findComment-12789150
