Looking for a vertical mount monitor
TastyGuava
I was wondering if anyone has vertical mount monitor recommendations? I'd prefer it to be 24-inch, DisplayPort, and 70hz+
As in... Portrait mode?
Or a monitor that mounts to the wall?
Screwdriver specs: Long, pointy. Turns things. Some kind of metal.
Main rig:
i9-7900x | Asus X299-Prime | 4x8GB G-Skill TridentZ @3300MHz | Samsung 970 Evo 500GB | Intel 5400S 1TB | Corsair HX1200
unRAID server:
Xeon  E5-1630v4 |  Asus X99-E WS | 4x8GB G-Skill DDR4 @2400MHz | Samsung 960 EVO 250GB cache drive | 12TB spinning rust | Corsair RM750X
FreeNAS server:
AMD something-or-other | Asus prebuilt sadness | 8GB DDR3-1600 | 9TB magnetic storage | Potential fire threat
HTPC:
i7-4790 | GTX1650 | Dell Sadness | 12GB DDR3-1600 | Samsung 860 250GB | 1TB magnetic storage | James Loudspeaker SPL3 x2 | Corsair SF450
Portrait mode, sorry for that mix up
So any monitor with VESA-compatible mounting points, plus an aftermarket VESA stand.
That gives you a lot of choices...
Edit: Something like this using only one of the mounts would give you tons of vertical clearance:
https://www.newegg.com/black-tripp-lite-ddr1527sdc-tools-and-hardware/p/15Z-004J-00036?Description=VESA stand&cm_re=VESA_stand-_-15Z-004J-00036-_-Product
Main rig:
unRAID server:
FreeNAS server:
HTPC:
Ouuu Alright
