I'm relatively new to the PC world however, i'm looking to buy a PC within a budget of £500-£600 i'm not that knowledgeable on building a PC which is why I've been looking online on amazon and eBay searching for pre-built PC's.
Realistically I've been leaning to the Intel core i7 side a bit more than the others
If you could help me with some better deals please let me know, i have heard it is cheaper to build a PC so i am down to also give this a shot so if you can please help with a specifications on parts to buy?
-From UK
-System will be used to do mostly trading and i'd give gaming a shot on this (edited)
-I'll be running most likely a 1-2 monitor setup
-Do not need keyboard & mouse
Edited by Thrillseeker1
https://linustechtips.com/topic/1090399-pc-build-help/
-From UK
-System will be used to do trading and gaming
600 pounds is nothing for a PC however I'll do my best to compose a list for you. Check back in about 1 hour or something.
Main Rig (Gaming, Programming, Video & Photo Editing, Server Management)
PC Specs:
CPU: Intel Core i5-9600K (3.7 GHz, 6-Core Processor)
Cooler: Deepcool GAMMAXX GT (29.5 CFM)
Motherboard: Asus PRIME Z390-A (ATX LGA1151)
Memory: Corsair Vengeance RGB Pro (16 GB, 2 x 8 GB, DDR4-3200)
Storage: Samsung 860 Evo (500 GB, 2.5" SSD)
Storage: Western Digital Caviar Blue (1TB, 3.5", 7200RPM HDD)
Storage: Seagate Barracuda Compute (2TB, 2.5", 7200RPM HDD)
Graphics Card: MSI VENTUS XS OC (GeForce RTX 2060, 6GB, 1365MHz)
Case: NZXT H510 Elite (ATX Mid Tower Case)
Power Supply: Corsair RMx 750W (White, 80+ Gold Certified)
OS 1: Windows 10 Home (64-Bit)
OS 2: macOS High Sierra
OS 3: Ubuntu 18.04 LTS
Peripherals & Setup:
Monitors: ASUS VG278Q (1080p, 144Hz, 1ms Response) (x3)
Camera: Canon 500D + 8-135mm IS
Webcam: Logitech BRIO
Keyboard: Logitech G413 (Carbon, Wired)
Mouse: Logitech G502 Proteus Spectrum (Wired, Optical)
Desk: IKEA LINNMON / ADILS (Table, Black-Brown, Black)
Headphones: SteelSeries ARCTIS 7 2019 Edition 7.1 Channel Headset
https://linustechtips.com/topic/1090399-pc-build-help/#findComment-12779096
What alternatives can I look at?
Also if i was to cheap out on other parts how much of the performance would really be affected?
Was quite hard but I made you a 700-800 pound build
https://uk.pcpartpicker.com/list/JpYhnH
PC Specs:
https://linustechtips.com/topic/1090399-pc-build-help/#findComment-12779113
here is my suggested build. This like the lowest of the low if I were to build it for myself. Anything crappier than this, would rather save up until I have more to spend or go with a AMD Ryzen.
PCPartPicker Part List
CPU: Intel Core i7-8700 3.2 GHz 6-Core Processor  (£279.99 @ Amazon UK)
Motherboard: Asus Prime B360-Plus ATX LGA1151 Motherboard  (£91.48 @ Ebuyer)
Memory: G.Skill Ripjaws V Series 16 GB (2 x 8 GB) DDR4-2666 Memory  (£66.88 @ Amazon UK)
Storage: Crucial MX500 250 GB 2.5" Solid State Drive  (£41.01 @ Amazon UK)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive  (£36.78 @ Aria PC)
Video Card: MSI Radeon RX 570 4 GB ARMOR OC Video Card  (£118.48 @ Ebuyer)
Case: Corsair 100R ATX Mid Tower Case  (£47.56 @ Amazon UK)
Power Supply: Corsair CXM 750 W 80+ Bronze Certified Semi-modular ATX Power Supply  (£70.00 @ AWD-IT)
Operating System: Microsoft Windows 10 Home OEM 64-bit  (£85.00 @ Amazon UK)
Total: £837.18
Generated by PCPartPicker 2019-08-05 04:27 BST+0100
https://linustechtips.com/topic/1090399-pc-build-help/#findComment-12779118
-Moved to New Builds and Planning-
https://linustechtips.com/topic/1090399-pc-build-help/#findComment-12779122
I'll recommend something like this instead...
CPU: AMD Ryzen 7 2700 3.2 GHz 8-Core Processor  (£181.36 @ CCL Computers)
Motherboard: ASRock X370M Pro4 Micro ATX AM4 Motherboard  (£59.69 @ Egenisys)
Memory: Team T-FORCE VULCAN Z 8 GB (1 x 8 GB) DDR4-3000 Memory  (£30.18 @ Aria PC)
Storage: Crucial P1 500 GB M.2-2280 NVME Solid State Drive  (£54.57 @ Amazon UK)
Video Card: XFX Radeon RX 580 8 GB GTS XXX ED Video Card  (£159.00 @ Amazon UK)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  (£39.99 @ PC World)
Power Supply: Cooler Master MasterWatt 550 W 80+ Bronze Certified Semi-modular ATX Power Supply  (£54.99 @ Box Limited)
Total: £609.96
Generated by PCPartPicker 2019-08-05 04:42 BST+0100
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1090399-pc-build-help/#findComment-12779154
3 minutes ago, Schnoz said:
I strongly suggest getting Ryzen 3XXX processors (Ryzen 3/Zen 2). They're literally as fast as i7s in most single-threaded applications (like gaming) and higher-core count parts like the 3950x demolish Intel's chips in multithreaded workloads (like Cinebench). They're also much more efficient and dirt-cheap for the performance
I've been looking at the AMD Ryzen processors and they're a lot cheaper (unsure on how powerful they were) but I've been used to Intel nearly my whole life thats why i was unsure on the AMD CPU side so I'd also be down to look at AMD CPU's
I've found some:
https://www.ebay.co.uk/itm/Intel-CORE-i7-8th-Gen-Gaming-PC-Coffee-Lake-8700-8GB-1TB-ULTRA-FAST/253272390652?hash=item3af835fbfc&_trkparms=ispr%3D1&enc=AQAEAAADAKvsXIZtBqdkfsZsMtzFbFsbX3WcW5fmB%2Fx7ZbaZTyexzaxNn9sQjT9HA83lHCjBO2%2BY%2B8AanrjFsZJaiBlU3FqYno%2B7l1qxKh%2FYQvSv4yZswr5C1ncouYEo0gWaS2n4KyjV141gEriEvQGd0YjXGKj2VGqs2MW%2BU9ab6beqZC7JZphJJDWGGD8WL4QaIjc%2FXPFdV4GJ%2Fuj%2B3blRmMT%2FNH4caQG9k46gbcS7h0giGNSoPHFzCrHKq4M0nz0%2F6NeX86eQGbT9zWAunDNUpcqITLNdyphswgdh2hEvoGAKxQgRozU5VInOost2OwYyqISNTNQZUXT920MV%2BBHLQdQknFNl6j6sm78j%2BMrHrlwQy4VpJheVKT3yRyum6OunsbmXPramDschCF2Y5qqnrDRWtb7f5V7IqXGVRkxvU7kGDCWz8J%2FcQuC%2BH%2Fgftb8LNy%2FuVPBC%2BW3KZaXt1y%2FZRfOkPaqDFMopNAYgmtXEQjKC%2BNxTM%2FII%2FXCYD32m%2FkoqrCkfEB9kspUhONjwqPFrNcOrGsPeGDqQ%2Btn6qTQNNPwC0LNaw48bgwhGm0AEakSVEGe8WPjYg0PyXEmK1YG50q%2Bs4a1ELLkG6xbD9Ggzn7nst%2F61rftwRFPDkX3aknTlrAHRttEinDalnp5Z3yt51OWRuIlzDCkFL4GAPqS50GCUbmLwPBmgUBGHts0L4wmXbaWRDdSxuTvpUONAI3YnAZL%2FJFiBstEjj9ejIsvuh2iaz%2FgRe9ry8U%2FG22OIpMDJhoT8YIA2qz8olP8UWqi6O42yG5J7AtN7yCJ%2BPCFSm%2BwTztZIvbWkL%2FiP2g9qgulR2tkny%2FwxXan48FvUSIEyNnin5eZCj52TVNvkDPaSigZMrlRy9AMljaMytNEVHnpztlKTctgCOY9SrE8RsgsS2ss3l5sRghxs4F6uZoHBOT29soRareGyB%2FuiSoFdvbaW6hXDi0xuK4r8eBbFdm9Z2ivm3o2taxoemQcuS%2BI%2BTKERQU8FBUZd8KaNDrYOMjBSlyX5hA%3D%3D&checksum=253272390652392fbce2b1a440ecbe005d83f66dc6bf
https://www.ebay.co.uk/itm/FXPC429-NEW-AMD-RYZEN-5-3400G-8GB-DDR4-VEGA-8-120GB-SSD-WINDOWS-10-GAMING-PC/113816642516?hash=item1a800023d4:g:KSgAAOSwyVRdIkhh
-I'll buy gpu probably a rx570
https://www.amazon.co.uk/ADMI-Gaming-PC-Falcon-Windows/dp/B01IPH2638/ref=sr_1_16?crid=3C7HNBQB9YG6C&keywords=gaming+pc+vr+ready&qid=1564973111&s=gateway&sprefix=gaming+pc+VR%2Caps%2C153&sr=8-16
-I feel like the AMD's are better than this one
https://www.amazon.co.uk/CyberpowerPC-Wyvern-1060-Gaming-PC/dp/B07D4MLWBZ/ref=sr_1_13?keywords=gaming%2Bpc&qid=1564972229&s=gateway&sr=8-13&th=1
https://linustechtips.com/topic/1090399-pc-build-help/#findComment-12779155
Total: £609.96
This seems promising just unsure on this message
  • Warning!Some AMD X370 chipset motherboards may need a BIOS update prior to using Pinnacle Ridge CPUs. Upgrading the BIOS may require a different CPU that is supported by older BIOS revisions.
  • Note:The motherboard M.2 slot #2 shares bandwidth with a SATA 6.0 Gb/s port. When the M.2 slot is populated, one SATA 6.0 Gb/s port is disabled.
  • Note:Some physical dimension restrictions cannot (yet) be automatically checked, such as cpu cooler / RAM clearance with modules using tall heat spreaders.
https://linustechtips.com/topic/1090399-pc-build-help/#findComment-12779160
By now, all the x370 mobos have been updated. No need to worry on that.
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1090399-pc-build-help/#findComment-12779163
As listed above, we are using an nvme drive. If the m.2 slot is populated, then one sata port is disabled. No big deal in that.
Also, that Mobo, ram and cooler fit in that case easily. I have made many builds in that case. PC part picker gives that message most of the times when it is unable to verify whether it fits or not.
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1090399-pc-build-help/#findComment-12779182
I've found some:
I Also gave it a shot of building a PC and came with this
-In the future i'll get a GPU or ill get a cheap GPU for the time being and then upgrade in the future?
https://linustechtips.com/topic/1090399-pc-build-help/#findComment-12779215
Current 8700 is overpriced. No point in going with it.
Ryzen is a better option. Also what will you be doing with this PC? You'll need a graphics card if you are planning to use it for gaming.
Traditional 7200rpm drives are slower and perform nowhere near to the ssds. Ssds are more than 10 times faster than hard drives. I'll recommend to get a ssd instead.
I'll make a list again.
Motherboard: MSI B450M GAMING PLUS Micro ATX AM4 Motherboard  (£71.99 @ CCL Computers)
Total: £622.26
Generated by PCPartPicker 2019-08-05 05:16 BST+0100
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1090399-pc-build-help/#findComment-12779226
Total: £622.26
I'll be using it to do trading mostly and if I've got the spare time i'll do some gaming on it hence the reason on why i didn't opt for a GPU (i understand seems abit stupid) however, i am probably going to go for the build you have sent most likely, just leaving some open options on my plate now if i can find anything better, or if anyone else can.
https://linustechtips.com/topic/1090399-pc-build-help/#findComment-12779231
Total: £622.26
This one doesn't have any compatibility issues. B450 boards support zen+ CPUs out of the box .
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1090399-pc-build-help/#findComment-12779258
3 hours ago, Thrillseeker1 said:
Thanks! Appreciated the help but i'm on a tight budget
If your on this type of a budget, I'd suggest saving up a little more because if you just flat out buy a build now your gonna have a hard time getting parts, etc.. Your budget is super cheap if that counts for not only your build but also your setup then that is way too little for it all. Even for just a build, not good amount for what you want.
PC Specs:
https://linustechtips.com/topic/1090399-pc-build-help/#findComment-12779408
I'm just curious what you think the 8700 is offering you on this build, especially with a junk MOBO, insufficient RAM, no SSD...
For multi core performance, SMT beats out Hyperthreading in performance and efficiency, so the R7 2700 makes so much more sense if you need those 16 threads for workload processing. The 8700's locked multiplier is a ding to longevity as well.
Further just a 12 threaded R5 3600 computes just as well, if not better due to higher core efficiency and computes per clock.
https://linustechtips.com/topic/1090399-pc-build-help/#findComment-12779514
R7 2700 should be better in this case.
SSD TIER LIST
CPU - Ryzen 7 3700X
https://linustechtips.com/topic/1090399-pc-build-help/#findComment-12779726
