I just built my new computer and it will turn on with all the case fans, the graphics card fan and the motherboard rgb, etc. But when I plug it into a monitor it will do nothing, I’ve tried 2 different monitors with 3 different cables. I am thinking maybe the cpu isn’t sitting right from what I have read, idk though
ryzen 5 2600x
rog strik b450-f
16gb of Corsair ram
1060 6g from evga
https://linustechtips.com/topic/1090262-won%E2%80%99t-post/
ryzen 5 2600x
rog strik b450-f
16gb of Corsair ram
1060 6g from evga
Does ur Motherboard have a speaker so u could hear beeps or a screen that shows error codes
https://linustechtips.com/topic/1090262-won%E2%80%99t-post/#findComment-12777987
I don’t hear any thing, all it says is that no cable detected. I tried using my motherboard ports and my graphics card ports
https://linustechtips.com/topic/1090262-won%E2%80%99t-post/#findComment-12778000
The Motherboard ports are useless that ryzen chip has no igpu mhh ye without a speaker its hard to find what the problem is cause u dont have a errorcode
https://linustechtips.com/topic/1090262-won%E2%80%99t-post/#findComment-12778011
I know I can eliminate issues with everything except for the cpu but I’m not to sure what the issue could be
https://linustechtips.com/topic/1090262-won%E2%80%99t-post/#findComment-12778016
