Ryzen 5 2400g & RX 570 build
EL02
I have a pc with R5 2400g, 16gb ddr4 2666mhz, gigabyte a320m s2h(i didnt plan on overclocking so i chose this one), 240gb ssd. I want to add a RX 570 4gb and want to know what power supply is good enough for this build. I have a bad 500w Force psu which hasnt caused any problems, but im worried.
1 minute ago, LukeSavenije said:
and you should be
budget and country?
Maybe around $40-45. I live in Albania(everything is overpriced here, newegg or outlet pc dont ship here).
do you have any website for me?
Amazon. No one really sells any good psu here.
6 minutes ago, EL02 said:
An amazon link would be helpful. Is 450w enough?
just look for cx450, you'll find it no problem and my links could have a dutch tag
450 is enough, you can't really fit more into your budget
Ok thanks! Is the psu im using right now good if i dont add any components, because i need to save some money.
I'm skeptical about it... I'd just get the cx as soon as possible
Yeah.... The only thing is that a pc with core 2 duo(pre built) costs around $400 here(crazyyy) and i was lucky to find this one for $450(wifi card added). Thanks anyways. I might try to sell it for a higher price like $500 and then build it myself. Idk.
