It got me wondering how can the msi trident x ( the mitx case woth i9900k and 2080 ti ) run soo cool under heavy load with no intake or exhaust fans and not be able to mimic these kind of temprature  in the ncase m1 or the ghost s1 even with biefer coolers . (Am planning on building a pc with these specs tho the thermals have been an issue )
https://linustechtips.com/topic/1089171-mitx-case-thermals/
it'd better be that good when its this much more expensive than building yourself
there is quite some room around the graphics card so it doesn't suffocate the card like other small cases. As for the CPU, I suspect MSI to run a factory undervolt.
Desktop benching:
https://linustechtips.com/topic/1089171-mitx-case-thermals/#findComment-12769409
The same gpu in the ncase m 1 got enough space aswell but it still throttles , cpu wise , undervolted 9900k reaching 4.3 ghz ?
https://linustechtips.com/topic/1089171-mitx-case-thermals/#findComment-12770079
Undervolt is not underclock
Desktop benching:
https://linustechtips.com/topic/1089171-mitx-case-thermals/#findComment-12770310
3 hours ago, Jood99 said:
Doesnt undervolting result in lower clock speeds ?
no. If you overdo it then you will need to lower frequency to maintain stability, but usualy when doing undervolting, we're implying that performance (frequency) doesn't change
Desktop benching:
https://linustechtips.com/topic/1089171-mitx-case-thermals/#findComment-12770615
Oh , alright . Didnot know that thnx for the information
https://linustechtips.com/topic/1089171-mitx-case-thermals/#findComment-12772714
