Cpu temperature high for its usage.
Go to solution Solved by Mira Yurizaki,
Usage only means how often the CPU was not running the System Idle Process.
If you really want to figure things out, run Cinebench a few times in succession and see what your CPU settles at.
Oh boi, i'm gonna ask a lot of things today haha.
Here i go, my ryzen 7 2700x is on idle at 54 - 65 ( with things opened) 37 -45(totally idle) and 85(gaming)
I wonder how much it will go when it reaches 100% usage on renders, because while gaming it was at 14% usage !!!
I highly hope its wrong readings by msi afterburner.
https://linustechtips.com/topic/1088791-cpu-temperature-high-for-its-usage/
have u tried using a different piece of software to read the temperature?
MSI afterburner in my experience doesn't read well on my board its at 49*C all the time, min and max.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
So usage doesn't mean the amount of work the cpu was handling ?
The best way for reading the temperature is direct from the bios but its a pain to keep booting into the bios and checking.
If u think its to high and if your confident enough to do so u could always try cleaning off old thermal paste and applying something a bit better.
What cooling solution u using?
Internet Speed.....
The out of the box, Wraith Prism and it already had a thermal paste.
Its probably wrong, when i touch the air exit flows, i can feel its cold.
Gonna try the 3d mark to see what changes...
Correct.
I don't have any hard evidence but the reasons I can think of as to why are:
  • It's invasive to keep tabs for every app on this information that, for the most part, isn't very useful to people most of the time.
  • It's hard to precisely define in a meaningful way how much "work" the CPU was doing
  • It's outside the scope of what Task Manager should be doing
after 85*c if its the thermal limit u will get thermal throttling which will slow ur system down.
since the processor isnt gonna hit a max of 100% for any prolonged time unless ur gaming or constantly running benchmarks id say u should be ok.
Internet Speed.....
Do you think this is normal for this cpu, or should i get a complain about this one ?
u should be fine.  no complaints needed.
Internet Speed.....
Just one last thing. Remember when i said with chrome opened and other things temps get at 56 - 67.
Apparently its 39. Idk which one is telling the truth here. Anway, im good. Thanks again.
How do u get AMD Ryzen master to work i still get the error.....
Ryzen master can only run with Virtualization based security VBS disabled in windows operating system which it is and still wont work.
Its been uninstalled and so has ryzen master and still wont work.
Internet Speed.....
i dunno man, i just downloaded and it works...
