Hello the stock fans in my switch 810 and some corsair sp120's are really loud!
The corsair sp120's are especially annoying, since one of them are makinga an odd buzzing noise and the other one makes a irregular whineing noise when it wants.
So i am thinking about investing in some quality fans to replace all my fans in one shot
I am looking for 120mm PWM fans and some 140mm 3pin fans
The PWM fans are for my h100i to run in push-pull (i know there is little to none performance benefit, just want beastly setup xD) + i need the best to keep my 3930k OCed to 4,4ghz cool.
I have some 4pin fan splitters that i will be useing on the PWM fans so that i can control them with my motherboard.
and the 140mm's ill just plug strait to the fan hub that came with my switch 810.
I dont want noctua fans, I have some of them in my media pc and they are fantastic and silent, but i just can stand the color scheme and since my case have a window thay are sadly out of the question.
Yesterday i stumbled across some noiseblocker on the interwebz.
I noticed that they had both the 120mm PWM and the 140mm fans that i desired.
the noiseblocker black silent pro PLPS 120mm
and the noiseblocker black silent pro PK1
Now, people say that they are just as good as the noctsua just with a better color scheme.
So i guess my question is, have any of you guys had any good or bad experience with these fans?
And if you know of any fans that might be better please let me know...
Intel 3930K @ 4,4ghz | Asus Rampage IV Extreme | Corsair Dominator GT 16gb | EVGA GTX 680 Classified | Asus Xonar Xense | Corsair HX 1050 | Corsair H100i | Corsair Force 3 120gb | Western Digital 2tb Black |
https://linustechtips.com/topic/10883-noiseblocker-fans/
Got a Coolermaster 140mm a weak ago looks just like the 140mm you posted and its pretty good for a case fan (goof CFM, bad presure)
Heres a review for the coolermaster and for those 2 noiseblockers too: http://www.tomshardware.com/forum/331629-28-cooling-roundup-2012
https://linustechtips.com/topic/10883-noiseblocker-fans/#findComment-116254
Noctua all the way I know they are ugly but just dye the plastic and you got the best fans ever. But I have never used NoiseBlockers before but from what i hear they are pretty good fans I always see high end builds with them.
https://www.youtube.com/user/SingularityComputers
https://linustechtips.com/topic/10883-noiseblocker-fans/#findComment-116486
Ok thanks people xD i desided to give the noiseblocker fans a try...
https://linustechtips.com/topic/10883-noiseblocker-fans/#findComment-117059
