What cooler, case, and ram do you currently have?
Where are you shopping / located? Budget?
Moved to Air Cooling.
https://linustechtips.com/topic/1087574-cooling-a-9900k/#findComment-12757370
4 minutes ago, jasonw99 said:
I have a stock CPU cooler right now, a Meshify C and 16GB 2133mhz RAM. I'm keeping the case and upgrading the other 2.
In the UK, around and I'd say maybe £100 on the cooler? The budget is kinda flexible though.
for 100 pounds i'd go directly to the Noctua NH-D15, it should be the best air cooler around
https://linustechtips.com/topic/1087574-cooling-a-9900k/#findComment-12757390
How much of an OC could I expect from a D15?
1 minute ago, The_Tron said:
why not a noctua nhd15
I say air coolers. Linus even made a vid where a beefy air cooler beat a much more expensive AIO by quite a bit
Yeah I've seen that video, but can a large air cooler work as well as an AIO on a 9900k?
https://linustechtips.com/topic/1087574-cooling-a-9900k/#findComment-12757397
Can you be more specific about the ram? If the ram is too tall, that would limit the coolers that may fit.
Make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them
https://linustechtips.com/topic/1087574-cooling-a-9900k/#findComment-12757629
I'll likely be upgrading to Corsair Vengeance RAM, which are pretty short dimms. PCPartpicker hasn't flagged anything.
https://linustechtips.com/topic/1087574-cooling-a-9900k/#findComment-12757688
Which Vengeance? LPX? RGB?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1087574-cooling-a-9900k/#findComment-12757700
3 minutes ago, jasonw99 said:
LPX
Ok, that fits under pretty much every cooler. And as for your question about OCing. D15 and be Quiet! Dark Rock 4 Pro are the best air coolers you can get. Both beat 240-280mm AIOs. And can even trade blows with bigger AIOs. So you should be able to get whatever the average for that chip is (5.1GHz?)with decent load temps. But what the actual numbers are depend on the chip itself.
https://linustechtips.com/topic/1087574-cooling-a-9900k/#findComment-12757723
1 hour ago, jasonw99 said:
LPX
LPX is standard height which all coolers are designed to clear.
As mentioned, the NH-D15 is about as good as it gets.
Alternatively, you could get the NH-D15S with an additional NF-A15 for better pcie clearance:
https://uk.pcpartpicker.com/product/xCL7YJ/noctua-cpu-cooler-nhd15s
https://uk.pcpartpicker.com/product/znPfrH/noctua-case-fan-nfa15pwm
If you want to save a bit of money, you could just go with the cheaper Macho Rev. B: https://uk.pcpartpicker.com/product/4TCrxr/thermalright-cpu-cooler-machorevb
or just the NH-D15S without the extra fan.
https://linustechtips.com/topic/1087574-cooling-a-9900k/#findComment-12757901
11 hours ago, jasonw99 said:
Planning to upgrade to 9900k and would like to achieve a moderate to high OC, can I do this on a large air cooler or is water a must? Any suggestions for a cooler that's not too expensive?
Curious, do you already have a compatible motherboard?
NHd15, Dark Rock Pro 4, Scythe Ninja 5
I thought they competed with 240mm AIO's
https://linustechtips.com/topic/1087574-cooling-a-9900k/#findComment-12758539
They are proven to be better performing, not just better price/performance ratio. Only triple-rads perform better, but would still lose in price/performance.
There are still situations where SIO can be seriously considered, but then buyer has something else beside performance or noise as priority (looks, case support, bias etc).
https://linustechtips.com/topic/1087574-cooling-a-9900k/#findComment-12758576
Can attest to some of these.  I have D15 cooling 9900k, using corsair LPX.  They fit under almost anything, def the D15 as well.
Multiple people have tested D15 and DRP4 against 100$+ aios and they can hang for sure.  At stock no difference (except the D15 is quieter).
In terms of OC, yes you can potentially get an OC but chip dependent.  I got kind of a hot chip that requires somewhat higher voltages to be stable at 5.1 and 5.2 respectively.  Due to that, the D15 cant keep up with the 5.2 (start spiking over 100, def not stable) but I have gotten 5.1 stable.  If I was lucky as some of these folks who post their stable 5.1 OC at 1.28-1.30v then I am certain I could get 5.2 stable, but unfortunately mine won't stay stable at 5.1 without a Vcore over 1.35, so it gets hot.  The D15 should be able to do all core 5.0 (still super fast) and might be able to do 5.1.
El Zoido:  9900k + RTX 4090 / 32 gb 3600mHz RAM / z390 Aorus Master
The Box:  3900x + RTX 3080 /  32 gb 3000mHz RAM / B550 MSI mortar
https://linustechtips.com/topic/1087574-cooling-a-9900k/#findComment-12759252
