Did you use DDU in safe mode?
Personal Desktop":
Luna, the temporary Desktop:
20 minutes ago, 1bonbri said:
actually no, imma try that right now
Edit:nope didnt change anything
this is weird
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
1 hour ago, 1bonbri said:
yep
My old pc had AMD graphics and when I replaced it to nVidia the control panel didn’t work this was in Win7 and had to reinstall a fresh windows and everything worked perfectly.
My PC:
CPU: AMD Ryzen 5 2600X Processor (4.4Ghz), MOBO: GIGABYTE X470 AORUS Gaming 7 WiFi (AMD Ryzen AM4/ X470/ Intel Wave 2 WiFi/M.2), RAM: Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3000MHz C15, GPU: Gigabyte nVidia GeForce GTX 1080 Windforce OC GV-N1080WF3OC-8GD Graphics Cards, STORAGE: 120GB CRUCIAL SSD, 1TB WD BLUE, COOLER: Cooler Master 212 EVO RGB Black Edition, FANS: 4 x MasterFan MF120R RGB (2 Front, 1 Back, 1 Top), 1 x Noctua NF-P12 Redux 1700 RPM(Back off Cooler), PC CASE: Cooler Master MB500 case, PSU: EVGA 750 BQ.
My Kids PC:
CPU: AMD Phenom II x4 955 (95watt @3.5Ghz @1.40V), MOBO: ASUS M2A-VM, RAM: Kingston 8GB (4x2GB) DDR2 800MHz, GPU: nVidia GT 710 2GB DDR3 (OC’ed Clock to 1300Mhz and Memory to 950Mhz), STORAGE: 250GB HDD, 500GB HDD, COOLER:  Cooler Master 212 EVO, PC CASE: Cooler Master Q300L , FANS: 3 x upHere RED LED Fans (2 Front, 1 Back), PSU: Generic 300 Watt PSU.
Console:  PS4 - vjizzle2384
Thats what I did and it worked
sometimes the nvidia control panel f's up. mine at one point simply didnt even show up anymore till i manually found it and placed it on my task bar. i highly suggest you do the same. never had issues after doing that with it.
PC:
MSI MPG X870E CARBON WIFI                            (motherboard)  |    Powercolor RX 9070XT Red Devil    (Gpu)
ryzen 7 9800X3D        (cpu)   |   2560x1440 165hz (phillips 27m1c5500v)    (Monitor)
ARCTIC Liquid Freezer III Pro A-RGB 420                (cpu cooler)  |  seasonic focus plus gold 850w      (Psu)
Lian Li O11 Dynamic EVO XL                                         (PCcase)    |  Kingston FURY Beast RGB 32 GB (2 x 16 GB) DDR5-6000 CL30   (Memory)
Steel series apex pro                                                  (keyboard)   |   Razer Basilisk v3 pro    (mouse)
https://pcpartpicker.com/user/hollyh888/saved/LX2cYJ
I’m glad it worked
My PC:
My Kids PC:
