I'm trying to put together a new rig for the road before my laptop takes a dump. I spend most of my time on the road doing cad, gaming and other design. Mostly solidworks.
Can anyone recommend a large ish sturdy case that'll support my graphics card? I'm debating on making a soft platform for the case to sit on with some up/down side to side travel to reduce hard shock from things like speedbumps. Is there such a thing as making your case too rigid?
"Be excellent to each other."
"Fear is but the precursor to valor."
https://linustechtips.com/topic/1086365-solid-road-case-for-mobile-office/
Well, what is your GPU?
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
there are several small cases that would work pretty well for this (assuming you have normal size GPU), a silverstone ml08 might work nicely, you can get one with a handle and it has full size GPU support. I recommend something with a riser because bumps could put strain on the motherboard connector with a large heavy GPU in the slot.
why no dark mode?
Current:
Watercooled Eluktronics THICC-17 (Clevo X170SM-G):
CPU: i9-10900k @ 4.9GHz all core
GPU: RTX 2080 Super (Max P 200W)
RAM: 32GB (4x8GB) @ 3200MTs
Storage: 1TB WD Blue NVMe SSD
Displays: Internal 1080p@300Hz, Asus ROG XG-17 1080p@240Hz (G-Sync), Gigabyte M32U 4k@144Hz (G-Sync), External Laptop panel (LTN173HT02) 1080p@120Hz
Asus ROG Flow Z13 (GZ301ZE):
CPU: i9-12900H @ Up to 5.0GHz all core
- dGPU: RTX 3050 Ti 4GB
- eGPU: Radeon 6850m XT XGm 16GB
RAM: 16GB (8x2GB) @ 5200MTs
Storage: 1TB NVMe SSD, 1TB MicroSD
Display: Internal 1200p@120Hz
Minisforum MS-A2:
CPU: Ryzen 9 9955HX
RAM: 63GB (2x32GB) DDR5 @ 5600MTs
Storage: 2x 1TB Various NVMe SSD in RAID 1, 4x 10TB HGST Enterprise HDD in RAID Z1
I'm planning on a 2060 to 2080 if I can afford it. I'm hoping to add a proper cad gpu down the line but it's out of my budget atm. Definitely using a full size card. Would like raid capability for redundant spinning drives for my media and dual ssd also. My total budget is around 1500$ or so.
1 hour ago, Felenari said:
Doesn't have to be a small case either. I have 12x36x24 set aside space wise.
Well a case like the Silverstone ML08 would also mount the GPU in a way that it's not going to break the motherboard when jumping around due to stress. However, I have to ask what kind of modeling are you doing, as lots of rendering/simulation puts a hard load on the CPU of your choice, and the ML08 only allows for low profile tower coolers to be used
I'm in training to be a firearms engineer for competition firearms. Each assembly will be between 200 and 500 unique pieces. If the cooler butts up against the door of the case I can mod the door for a higher clearance. I have access to a full metal shop with the exception of a lathe and mill. I'm definitely going air cooled rather than liquid though. I'm currently a TAB engineer by trade so I can add extra airflow fairly easily.
14 minutes ago, Felenari said:
https://pcpartpicker.com/user/Felenari/saved/FLRCLk
Build so far. Not committed to ram or hdd. I know I want a 2080 or 2070 but not sure on brand.
Link says list is private
Ryzen 2600 - Sapphire Pulse Vega 56 - Corsair Vengeance LED DDR4 3000 C15 2x8GB - Corsair Force MP500 NVMe PCIe M.2 240GB - 2x Seagate Barracuda 2TB -
AsRock B450 PRO4 - Deepcool Earlkase Case -  Seasonic Foucus+ 650
