How are these fans as intake on front?
Tech Reprise
  • AMD Ryzen 7 5700X Stock
  • B550 Aorus Elite V2 Rev1.2
  • G.Skill TridentZ RGB 3600Mhz 32gb (8gb x4)
  • MSI Mech 2X RX6600
  • Deepcool AK620 WH
  • Deepcool CK500 WH
  • Kingston A2000 250gb + WD Blue 1tb HDD, Sn550 1tb + MX500 1000gb
  • Antec EAG Pro 750 80+G
  • Benq Mobiuz EX2510 144Hz
I use riing fans as front intake. They're good.
Primary PC:
i bought one to know it, but the non rgb version, just led, i found it to be noisy, it required the use of the extension that comes in the box that reduces speed
the led one is not that bright, perhaps the rgb is brighter
Riing fans are fine especially if you are into the RGB thing
What case?
3 hours ago, WoodenMarker said:
What case?
Spec 01
  • Deepcool AK620 WH
  • Deepcool CK500 WH
42 minutes ago, rounakr94 said:
Spec 01
i wouldnt use that case with those fans, the front covers almost both fans, so the rgb effect is lost, only seen from the side, and most of that side of the fan is covered, the left panel window is a bit small
10 hours ago, rounakr94 said:
Spec 01
They'd be functional for moving air. As mentioned, most of the lighting would be covered especially with 140mm's that extend past the front panel design.
If you just want functional fans, there are better options available.
Where are you shopping / located? Budget?
