thats the frequency the memory is running at and its basically how many read/writes per second the ram can do. in the past this had little to no effect on performance because a higher clock usually comes with higher latency but recently it is shown to have a significant impact for newer cpus. for ryzen 1000 and 2000 cpus its partly because their infinity fabric tickrate is tied to the memory tickrate but i think that is no longer the case for ryzen 3000 cpus
https://linustechtips.com/topic/1085216-ram-problems/#findComment-12740738
2 minutes ago, spartaman64 said:
thats the frequency the memory is running at and its basically how many read/writes per second the ram can do. in the past this had little to no effect on performance because a higher clock usually comes with higher latency but recently it is shown to have a significant impact for newer cpus. for ryzen 1000 and 2000 cpus its partly because their infinity fabric tickrate and tied to your memory tickrate but i think that is no longer the case for ryzen 3000 cpus
So is the 3rd option better than the 2nd option?
https://linustechtips.com/topic/1085216-ram-problems/#findComment-12740747
does it have better performance yes but its probably very small but at the same time 9 pounds is also a really small price difference so whether its worth it is hard to say for me
https://linustechtips.com/topic/1085216-ram-problems/#findComment-12740774
There is not enough information in the pic to know with certainty. While speed is very important, so to are timings, particularly CL.
According to https://www.techpowerup.com/review/amd-zen-2-memory-performance-scaling-benchmark/, there can be up to 5% difference in fps between the two memory choices ask about. Given that the cost differential is almost 30%, it doesn't seem worth the added cost. But that is a personal choice.
https://linustechtips.com/topic/1085216-ram-problems/#findComment-12740785
