The stuff in the quotes? That's caused by the poster using Grammarly. We will be disabling Grammarly on the editor in an upcoming update to prevent this from causing issues, but for now it can only be fixed by the poster turning it off for LTT.
HTTP/2 203
https://linustechtips.com/topic/1085142-weired-problem/#findComment-12740780
e̴̡̡̡̧̧̨̧̧̢̧̧̡̡̧̢̡̧̢̡̧̧̧̨̨̧̛̛̛̛̬͓̲̫̝̫̲͖̗̣̞̫̝̥̳͎̦͕͉̝͔̭͍͔͉̻̯͍̝̰̮͙̹̫̖̻̹̩̲̹͇̯͖̬͎̲̞̤̗̗͍͚̯̲̤͓̼̪͙͕͔̱̼͙̩̠͙͖̠̩̮̱̙̰̻̫̞̣̺̮͎͚͍͈͖̖̺̻̰͇̻͖̤̣͉̗̫͓̙͈̯͔̗͕̻̞̺̞̘͉̩̲̳̥̫̟̯̤͉̭͉͖̤̳͉̻̻̺̘͇͖͔͈͉̼̲͙͖̦̹̖̝͓̤̝̞̬̯̲͖̣̭̟̪͚͎̩͓̘̖͔̥̮̪̬̩͕̫̩̥̦̦͙̬̺͔͍̺̮͕̬̲͇̯̜̹̯̪͑̽͗̀́͂̂̂̂͐̈̆̈́̄̀̾̓͑͆́͊͆̓͋̇̈́͒̑͊̽̀̃̄͗̃̽̋̈́̈́͛̂̀̆̆͛̏̿̂́͗͒͗̒̀̉̇̉̾̾͊͛̒̎̓̉̄͆̉͌́̀͂̈̀͂͐̀̒́͒̌͌̆͋́̂͋͑̅̂̎́̇̈́̋͂̏̅́͛̈̔́̈́͑͗̒̃́̇̓̾̄̓̋̓̒̏̅͑͒̽̓̇̽́̌̊̑̄̏͑̓͒͊̄̾͂͂̌̿̃͊̔̈́͗̈́̉̍̄̋͆̾̂͑̃͋̂̿̊̇̆͒̑͂̂̂͗͌͌̑͊̔̾̀̈͗̒͑̑̈̏̈͐͐͌͑̉̅̾͆͋́͊̈́̇́̓̆̔͒͐̓̾̄̉̉́͛̀̏͒̆̈́̈͗̀̆̈́́͒͗̆͋̂̾̔̐̐̊̏̍͌͆̎͗̌̍̈̀͆͛̌̓̅͆̈͊̂̀̓̓͛̾̐̕̚̚̚͘̕͘̚̕̕̚̕̚̚͜͜͜͠͝͝͝͝͝͝͠͝͝͠͠͝͝͝͝͝͝͠ͅͅͅe̴̡̡̡̧̧̨̧̧̢̧̧̡̡̧̢̡̧̢̡̧̧̧̨̨̧̛̛̛̛̬͓̲̫̝̫̲͖̗̣̞̫̝̥̳͎̦͕͉̝͔̭͍͔͉̻̯͍̝̰̮͙̹̫̖̻̹̩̲̹͇̯͖̬͎̲̞̤̗̗͍͚̯̲̤͓̼̪͙͕͔̱̼͙̩̠͙͖̠̩̮̱̙̰̻̫̞̣̺̮͎͚͍͈͖̖̺̻̰͇̻͖̤̣͉̗̫͓̙͈̯͔̗͕̻̞̺̞̘͉̩̲̳̥̫̟̯̤͉̭͉͖̤̳͉̻̻̺̘͇͖͔͈͉̼̲͙͖̦̹̖̝͓̤̝̞̬̯̲͖̣̭̟̪͚͎̩͓̘̖͔̥̮̪̬̩͕̫̩̥̦̦͙̬̺͔͍̺̮͕̬̲͇̯̜̹̯̪͑̽͗̀́͂̂̂̂͐̈̆̈́̄̀̾̓͑͆́͊͆̓͋̇̈́͒̑͊̽̀̃̄͗̃̽̋̈́̈́͛̂̀̆̆͛̏̿̂́͗͒͗̒̀̉̇̉̾̾͊͛̒̎̓̉̄͆̉͌́̀͂̈̀͂͐̀̒́͒̌͌̆͋́̂͋͑̅̂̎́̇̈́̋͂̏̅́͛̈̔́̈́͑͗̒̃́̇̓̾̄̓̋̓̒̏̅͑͒̽̓̇̽́̌̊̑̄̏͑̓͒͊̄̾͂͂̌̿̃͊̔̈́͗̈́̉̍̄̋͆̾̂͑̃͋̂̿̊̇̆͒̑͂̂̂͗͌͌̑͊̔̾̀̈͗̒͑̑̈̏̈͐͐͌͑̉̅̾͆͋́͊̈́̇́̓̆̔͒͐̓̾̄̉̉́͛̀̏͒̆̈́̈͗̀̆̈́́͒͗̆͋̂̾̔̐̐̊̏̍͌͆̎͗̌̍̈̀͆͛̌̓̅͆̈͊̂̀̓̓͛̾̐̕̚̚̚͘̕͘̚̕̕̚̕̚̚͜͜͜͠͝͝͝͝͝͝͠͝͝͠͠͝͝͝͝͝͝͠ͅͅͅe̴̡̡̡̧̧̨̧̧̢̧̧̡̡̧̢̡̧̢̡̧̧̧̨̨̧̛̛̛̛̬͓̲̫̝̫̲͖̗̣̞̫̝̥̳͎̦͕͉̝͔̭͍͔͉̻̯͍̝̰̮͙̹̫̖̻̹̩̲̹͇̯͖̬͎̲̞̤̗̗͍͚̯̲̤͓̼̪͙͕͔̱̼͙̩̠͙͖̠̩̮̱̙̰̻̫̞̣̺̮͎͚͍͈͖̖̺̻̰͇̻͖̤̣͉̗̫͓̙͈̯͔̗͕̻̞̺̞̘͉̩̲̳̥̫̟̯̤͉̭͉͖̤̳͉̻̻̺̘͇͖͔͈͉̼̲͙͖̦̹̖̝͓̤̝̞̬̯̲͖̣̭̟̪͚͎̩͓̘̖͔̥̮̪̬̩͕̫̩̥̦̦͙̬̺͔͍̺̮͕̬̲͇̯̜̹̯̪͑̽͗̀́͂̂̂̂͐̈̆̈́̄̀̾̓͑͆́͊͆̓͋̇̈́͒̑͊̽̀̃̄͗̃̽̋̈́̈́͛̂̀̆̆͛̏̿̂́͗͒͗̒̀̉̇̉̾̾͊͛̒̎̓̉̄͆̉͌́̀͂̈̀͂͐̀̒́͒̌͌̆͋́̂͋͑̅̂̎́̇̈́̋͂̏̅́͛̈̔́̈́͑͗̒̃́̇̓̾̄̓̋̓̒̏̅͑͒̽̓̇̽́̌̊̑̄̏͑̓͒͊̄̾͂͂̌̿̃͊̔̈́͗̈́̉̍̄̋͆̾̂͑̃͋̂̿̊̇̆͒̑͂̂̂͗͌͌̑͊̔̾̀̈͗̒͑̑̈̏̈͐͐͌͑̉̅̾͆͋́͊̈́̇́̓̆̔͒͐̓̾̄̉̉́͛̀̏͒̆̈́̈͗̀̆̈́́͒͗̆͋̂̾̔̐̐̊̏̍͌͆̎͗̌̍̈̀͆͛̌̓̅͆̈͊̂̀̓̓͛̾̐̕̚̚̚͘̕͘̚̕̕̚̕̚̚͜͜͜͠͝͝͝͝͝͝͠͝͝͠͠͝͝͝͝͝͝͠ͅͅͅ
https://linustechtips.com/topic/1085142-weired-problem/#findComment-12740938
