I'm not sure what role it plays and in what stage of the cooling.  I think it might be what cools off coils that then has air run over them, but I don't think the Freon is meant to actively cool something much above ambient temps.
You should look up how a fridge works and that will probably answer your question.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
it could work but its much easier to buy a good watercooling settup xD you could modify a refrigerator engine ( dont know the term for it ) and have it trasner all the cooling to a block but you would be dealing with frostover
2 hours ago, RAMiles said:
Is it possible to use freon instead of water.
Freon is much cooler,  its whats used to cool fridgerators and freezers
In short, nope.
Long answer: By "freon", I'm going to presume you mean "refrigerant". And more specifically I'll presume you mean R-134A, which is commonly used in cars and readily available in automotive stores. Aside from the issues just trying to handle the stuff, most refrigerants aren't liquid at room temperature. R-134A - or 1,1,1,2-Tetrafluoroethane - has a boiling point of -15F. They are instead kept under heavy pressure inside the refrigerant system so they don't boil off nearly as easily.
If you want a refrigerant-based cooling system for your CPU, look into phase-change systems.
Wife's build: Amethyst - Ryzen 9 3900X, 32GB G.Skill Ripjaws V DDR4-3200, ASUS Prime X570-P, EVGA RTX 3080 FTW3 12GB, Corsair Obsidian 750D, Corsair RM1000 (yellow label)
My build: Mira - Ryzen 7 3700X, 32GB EVGA DDR4-3200, ASUS Prime X470-PRO, EVGA RTX 3070 XC3, beQuiet Dark Base 900, EVGA 1000 G6
Refrigerants are used because fridges and freezers work with phase change cooling. It would be pointless to use that stuff in a regular pc water cooling loop. Water has higher heat capacity.
If you want.phase change cooling you can buy ones for PCs for about $1-2k, those work with refrigerants like a fridge or air conditioner.
