Building my first pc, i had pcs before but this time i am building it myself and looking for a "most bang for the buck" graphic card for good 1080p gaming.
These are the prices of some nvidia gpus in my country,
GIGABYTE Nvidia Gtx 1660         US$ 285
GIGABYTE Nvidia Gtx 1660ti       US$ 345
GIGABYTE Nvidia Gtx 2060         US$ 430
GIGABYTE Nvidia Gtx 2060 Super US$ 510
Which one is most bang for my buck gpu, also how to calculate their relative performance (like how much % 2060 Super better than 2060 etc.).
https://linustechtips.com/topic/1083650-first-pc-build-nvidia-gpu-advice/
You really can't, at least very specifically, because it comes down to the model, resolution, game, etc. Of the cards you're considering, the 1660 offers the best price to performance, however that 2060 may come down in price a bit more and be a better contender.
Primary PC:
PSU tier list
How many watts do I need?
For 1080p you could get away with the 2060, but it's worth if you can get the Super
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
The most 'bang for the buck' graphics card for 1080p is none of those. The undisputed king of 1080p is the RX 570. The value of that card is unmatched, no card even comes close. You'll have to turn down settings to high or medium on some games, but for the most part you should still get 60fps in most games at ultra.
If there's some reason you can't get the 570, then out of the ones you have mentioned..the 1660 is the best option for 1080p 60hz, while the 2060 is the sweetspot for 1080p 144hz (low/medium in most cases).
-Threads merged-
Please do not make similar or duplicate topics about the same subject.
The RX 580 costs only slightly more than the RX 570 especially used but even new to a lesser extent and does considerably better getting 60fps on ultra for 1080p. The RX 590 is coming down in price but not quite there yet especially new.
In the used Nvidia category, 1060 6GB has been auctioning for only slightly over $100. A used 1070 is still pricey since they are going for about the same price as a new 1660 (non-TI) but sometimes go for significantly less.
