I have a question for h370 motherboards
I want to built a new pc with the i5 9400f and i dont know if i have to update the bios on a h370 motherboard (two of the mobos im planning to buy Gigabyte h370 aorus gaming 3 wifi (rev 1.0),Asrock fatal1ty h370 performance)
These boards will need a BIOS update before installing the new 9th Intel Processors unless otherwise stated (some boards might have shipped with the latest BIOS that supports such processors. Check for a sticker or label on the box)
Contact your retailer or local service center first and ask them to help you update the BIOS. Or borrow a friend's CPU to flash the BIOS.
"Mankind’s greatest mistake will be its inability to control the technology it has created."
Where are you buying from? In USD pricing, a B450 motherboard and ryzen 5 3600 is very competitive and you have a guaranteed method of updating bios through AMD customer support
Primary PC:
in greece the i5 9400f cost around 145 euros or 162.69 USD but ryzen 5 3600 cost 230 euros or 258.06 USD and B450 motherboards cost around the same with the H370
edit: sorry i didnt mention i live in greece and i didnt mention the prices
thanks
Ok. Also, personally I'd spring for a B360 board since H370 boards usually contain features from Z370 minus the overclocking, so if your needs are simpler, like 2666MHz ram, then you can save some money.
Primary PC:
