Suggestions for a decent case
_se7en
Any suggestions for a "value for money" PC case for below build?
ASRock - AB350 Pro4 ATX AM4
AMD - Ryzen 3 1300X
Cooler Master - Hyper 212 CPU Cooler
Cooler Master - MasterWatt 650 W PSU
I was thinking of below case but not sure if the CPU cooler will fit in.
https://www.newegg.com/black-corsair-carbide-series-175r-atx-mid-tower/p/N82E16811139141
get whatevers cheap with a breathable intake. If your system is choked for air it will suffer. you could also diy whatever case you get to have a breathable intake but that takes extra time & money
Mx330 from cougar.
32 minutes ago, _se7en said:
AMD - Ryzen 3 1300X
You dont need the aircooler
Get an r5 1600 instead and a cx450/550 PSU
@GoldenLag I already have the r3 1300 and it came without the stock cooler, so i would need an air cooler. If not Hyper 212, which one should I go for?
Go for the arctic freezer 33/34 Esports One/duo
