well you must have a budget in mind?
speculatively you should be fine with a build of around $800--900 for dam solid performance.
parts is a very deep hole, you will get better performance if you go with second hands parts. or do you want the safety but less performance (marginal) of new?
CPU AMD 5800x_____Asus Crosshair VIII_____Asus Strix LC 360_____RAM Corsair Dominator Pro 2x8Gb 3600mhz_____ASUS RTX 3080 Strix
PSU Corsair HX1000w_____CASE Lian Li 011 Dynamic (original choice right? w/9 UNI Fans)_____Keyboard Razer BlackWidow Chroma_____Mouse Razer Deathadder Chroma_____Headphones Bose QC25_____Monitor (1) Acer Predator XB1 144hz G-Sync  (2) Benq 144hz G-Sync
Microphone Blue Yeti Black
Razer Blade 14
Also an XBOX one s.
https://linustechtips.com/topic/1082032-help/#findComment-12711613
yeah 800-900 is prob ok thx
https://linustechtips.com/topic/1082032-help/#findComment-12711716
Is there a cheaper grafics card that might work like a 1060
https://linustechtips.com/topic/1082032-help/#findComment-12711786
3 hours ago, ....... said:
I mean i guess either one works and ok
I'd recommend something like this...
PCPartPicker Part List
CPU: AMD - Ryzen 5 3600 3.6 GHz 6-Core Processor  ($199.00 @ Amazon)
Motherboard: MSI - B450 Gaming Plus ATX AM4 Motherboard  ($84.99 @ Newegg)
Memory: OLOy - 16 GB (2 x 8 GB) DDR4-3200 Memory  ($63.99 @ Newegg)
Storage: ADATA - XPG SX6000 Pro 512 GB M.2-2280 Solid State Drive  ($57.99 @ Amazon)
Video Card: XFX - Radeon RX 5700 XT 8 GB Video Card  ($399.99 @ Newegg)
Case: SAMA - Proxima-RGB ATX Mid Tower Case  ($57.99 @ Newegg)
Power Supply: Rosewill - Capstone 550 W 80+ Gold Certified Semi-modular ATX Power Supply  ($59.99 @ Newegg)
Total: $923.94
Generated by PCPartPicker 2019-07-12 00:30 EDT-0400
SSD TIER LIST
CPU - Ryzen 7 3700X
Mobo - ASRock X470 Taichi
Memory - G.Skill Trident Z RGB (8x2 3200MHz)
Storage - Sabrent Rocket 1TB - Seagate Barracuda 2TBWD Black 1TB
GPU - MSI GeForce GTX 980Ti LIGHTNING
CaseFractal Design Meshify C
PSUSuper Flower Leadex II Gold 650W
https://linustechtips.com/topic/1082032-help/#findComment-12712363
Total: $923.94
Is this can or amarican
https://linustechtips.com/topic/1082032-help/#findComment-12716907
Hep i've been thinking about building a new PC or there's a possibility that i might buy one. I want it to be able to run games like overwatch, minecraft, dauntless. what pars do you suggest and how much do you think it will cost overall? And im in a price point from 800-1000 canadian
https://linustechtips.com/topic/1082032-help/#findComment-12716919
We'll need to know a lot more than that. What settings? What resolution? What refresh rate? There's a big difference in price between a PC that will run overwatch at 4k 120Hz and one that will run it at 1080p 60Hz.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
https://linustechtips.com/topic/1082032-help/#findComment-12716926
Probably put a good machine together for $1000-$1200, for those titles.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose. Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
https://linustechtips.com/topic/1082032-help/#findComment-12716928
If you click on the links, it brings you to pc parts picker USA.  So it's USD.  The site does allow you to select CND currency at top, but the links provided won't work.  You'd have to reselect them in the website build option.
Only concern on the list is the power supply, might be questionable quality (but since your on a budget you get what you pay for).
Radeaon RX 5700 XT are good value, but need some tweeking for driver which should occur in the next couple of months (you should always expect this for new release GPU). The blower on it is bad, if you can wait 1 month for the third-party coolers and get one of those, then you would be golden.
RAM appear to work with Ryzen.... but I cannot comment if you won't have issues.  I ran into that myself lately.
Really, for your budget, it's a good recommendation.  It is missing a windows 10 license however, unless you plan to run Linux.
https://linustechtips.com/topic/1082032-help/#findComment-12716949
https://linustechtips.com/topic/1082032-help/#findComment-12716951
https://linustechtips.com/topic/1082032-help/#findComment-12716955
Change your topic title to "$800-1000 CAD gaming build"
Edited by fasauceome
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1082032-help/#findComment-12717343
That depends, are you looking to buy all the parts brand new or used?
Motherboard: MSI B450m Mortar Max
Processor: Ryzen 7 2700 w/ Wraith Prism
RAM: Klev Cras X 3200mhz 8gb x2
GPU:  Zotac Mini GeForce GTX 1070ti 8GB
PSU: Seasonic GX-750
Case: Inplay Robin 101 + 10 fans w/ hub and remote
Storage: Toshiba 1TB, Western Digital WD Green 1TB, Crucial BX500 480GB
https://linustechtips.com/topic/1082032-help/#findComment-12717344
12 minutes ago, ThriversCap said:
Help i've been thinking about building a new PC or there's a possibility that i might buy one. I want it to be able to run games like overwatch, minecraft, dauntless. what pars do you suggest and how much do you think it will cost overall? And im in a price point from 800-1000 canadian
Duplicate post, user already posted this earlier.
Desktop: KiRaShi-Intel-2022 (i5-12600K, 5060 Ti) Mobile: Moto Razr 50 Ultra (Razr+ 2024) | 30GB CAN+US+MEX $30/month
Laptop: Lenovo Yoga 7i (16") 82UF0015US (i7-12700H, 16GB/2TB RAM/SSD, A370M GPU) Tablet: Lenovo Tab Plus (256GB)
Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 Music: Spotify Premium (CIRCA '08)
https://linustechtips.com/topic/1082032-help/#findComment-12717347
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($194.95 @ Vuugo)
Motherboard: ASRock - B450M Pro4-F Micro ATX AM4 Motherboard  ($80.25 @ Vuugo)
Memory: Team - Vulcan 16 GB (2 x 8 GB) DDR4-3000 Memory  ($74.99 @ Newegg Canada)
Storage: TCSunBow - X3 480 GB 2.5" Solid State Drive  ($57.99 @ Amazon Canada)
Video Card: Sapphire - Radeon RX 5700 8 GB Video Card  ($454.99 @ Newegg Canada)
Case: Cooler Master - MasterBox Q300L MicroATX Mini Tower Case  ($54.50 @ Vuugo)
Power Supply: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  ($79.99 @ Canada Computers)
Total: $997.66
Generated by PCPartPicker 2019-07-13 22:13 EDT-0400
https://linustechtips.com/topic/1082032-help/#findComment-12717544
