Hi, I am not able to get temperature readings from my new 3600 in any software except HWiNFO64. In there it shows 2 sections: "AMD Ryzen 5 3600 6-Core Processor" and "AMD Ryzen 5 3600 6-Core Processor: Enhanced", the temp is only shown under the enhanced section. The temp reading in there doesn't seem to be reliable either. It fluctuates from 42-59 while idle, really erratically. I have the latest BIOS, latest chipset drivers and the latest versions of the software I'm trying to use to read temps. I am running this on a B350 board. Other software I used that didn't show any CPU temp: HWMonitor, Afterburner/RTSS. Maybe it's just a BIOS/driver issue with B350 and Ryzen 3000? Anyone else have a similar setup and having the same issues or know what is causing this issue?
https://linustechtips.com/topic/1081663-ryzen-5-3600-no-temperature-readings/
Just now, Airdragonz said:
Having the same issue, except with a 3900x and x570 except my cpu temperature shows up under the motherboard section of HWINFO64. My guess is some driver or chipset issue.
Thanks for your input. Seems I'm not the only one then. Perhaps it's just a case of HWMonitor and other software needs to be updated to work correctly with 3rd gen Ryzen.
I'm having the same issue. I stuck my R5 3600 in an MSI B450M Bazooka Plus (with an updated Beta BIOS). It seems to be able to read the average temp on HWMonitor but won't give any individual core temps. The temp also won't display on the MSI Afterburner's Riva Tuner overlays.
On 7/15/2019 at 11:02 PM, Plutosaurus said:
Does hwinfo64 need to be updated?
Not even sure. I contacted AMD Support and they only told me to install Ryzen Master. Useless advice really since I already had Ryzen Master installed and even it won't read the individual core temps. Just for good measure, I reinstalled Ryzen Master. No dice. Awaiting support's reply again.
My ryzen master works fine on the b450 tomahawk and 3600 cpu. Same with hwinfo, have you deleted and reinstalled ryzen master? I had to do that for it to work right
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Pny 5070ti
Fractal Ion 2+ 860watt platinum
Thermaltake View 380
AW2725DF 1440p 360hz oled
Aoc Q27G3XMN mini led
Ps5 Pro
Series X
  • 1 month later...
5 hours ago, nullredvector said:
Is there a solution to the OP? Is reinstalling the answer?
I had this issue, upgraded CPU + MOBO etc, but used my old windows on my SSD with my old drivers. Reinstalled windows, installed chipset drivers for my motherboard (B450) and it fixed it. You should try it if you haven't.
