My build:
PCPartPicker Part List: https://pcpartpicker.com/list/nJvVhy
CPU: AMD - Ryzen 7 3700X 3.6 GHz 8-Core Processor  ($329.00 @ B&H)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($114.89 @ OutletPC)
Memory: Crucial - Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3200 Memory  ($77.99 @ Amazon)
Storage: Crucial - MX500 1 TB 2.5" Solid State Drive  ($107.40 @ OutletPC)
Video Card: Zotac - GeForce GTX 1070 Ti 8 GB AMP Edition Video Card
Power Supply: Corsair - RMx (2018) 550 W 80+ Gold Certified Fully Modular ATX Power Supply  ($79.99 @ Newegg)
Now: I am torn between NZXT H500 and CM NR600 case.
I prefer looks of NZXT, but CM has better CPU temps. Based on what Ryzen 3700x owners say, it reaches high temperatures(even up to 90 C).
Do you guys think better airflow/cooling is necessary with my CPU/GPU setup or can I afford worse airflow?
PS Already did my research, watched dozens of yt vids, gamer nexus reviews etc. Still cant make my mind.
Thanks.
https://linustechtips.com/topic/1081175-help-with-case/
The H500 has zero airflow, scratch it off your list
It's very important
https://linustechtips.com/topic/1081175-help-with-case/#findComment-12710678
if you like the looks of the h500, then look at the h700.  little bit bigger but much better airflow
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
https://linustechtips.com/topic/1081175-help-with-case/#findComment-12710684
