Hello wonderful people, yesterday I built a new computer using a r5 3600,  Gigabyte X470 Aorus Gaming 5 and CMK32GX4M4A2133C13 memory . After initially testing the computer I noticed my performance was lower then expected, after doing some research I now think its the memory causing this issue. So I was wondering if anyone could tell me some safe limits and give me some good settings I can run daily on this memory. Thanks for any responses :)
https://linustechtips.com/topic/1080292-basic-overclock-settings-for-ram/
1.45v max voltage for 24/7 use, stay totally safe then 1.35v.
Memory overclocking varies heavily between sticks so you will have to test on your own, there are no good settings others can recommend. That's why buying binned CPUs is usually stupid but high speed rated memory isn't (to a point for normal users of course).
Desktop benching:
8 minutes ago, alatron978 said:
1.45-1.5V is generally said to be the max voltage for ddr4 but personally i say below 1.43V. When it comes to timings if that kit is afr, try 14-17-17-28 1T at 2933mhz with 1.4V should be no problem (If it doesnt work lower frequency), if that works try 3066mhz etc. For stability testing run 12 instances of HCI memtest with 2200MB in each instance, i personally run to 180% and have never had issues on any systems running this.
Should I attempt modifying the secondary timings? If yes, can you give me basic settings that might work, these numbers go in one ear and out the other for me.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
On ‎7‎/‎10‎/‎2019 at 1:20 AM, alatron978 said:
Yes defiantly worth adjusting those, as for timings this 1st one should work <=3200mhz, 2nd one probs wont work but its fast.
image.png.89a50a69578dbd898be51fa59e716862.pngimage.png.d29b41c64acd5ef972f2d8ea60994446.png
Thankyou for this, I was able to get the first set of timings you posted stable at 3200mhz with 1.43V. ty ❤️ Also, I tested to 200% in memtest, is that enough?
