My Samsung J7 is acting weird and I want to back up the things I have before I reset it to factory. My only problem is that there are some files that I cant find, and the program that I used to create such files crashes the moment I try to open it (I have been trobleshooting it for a long time, I gave up). I cant find the files with androids device manager, third party programs or good old plug to PC and search manually. Best thing I could think about was using WinDirStat as it works really well on PC drives to find files based on size. So my next problem started: WinDirStat wont show the phone on its list. I guess that it's because windows wont assign a drive letter (such as E:) to a cellphone as it would do to any other USB drive. The attached image shows what I mean.
Is there a way to force WinDirStat to look for it? Or a way to assign a letter to the cellphone? Maybe another program build to do that?
https://linustechtips.com/topic/1079265-how-to-check-android-storage-using-a-pc/
I always use freefilesync to make back-ups of phones.
It can make a list of all the files on the device (might be enough for you) but it can also copy them to somewhere else without crapping itself like explorer does.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
