This was my CAMC 2018 Entry on the dazmode forums.
Components:
Mobo - ROG Maximus Code z370
CPU - i7 8700k Delidded/LM/Rockitcool Copper IHS
GPU - EVGA 1080TI FTW3
Ram - Teamgroup T-Force Delta 2 RGB 4x4
PSU - Corsair AX1000w (total overkill I know)
Storage:
M.2 - ADATA XPG sx8200 gen3 x4 240gb
SSD - Samsung 850 evo 500gb
SSHD - Seagate Firecuda 2tb
HDD - Seagate Barracuda Compute 4tb
Watercooling:
CPU - Watercool Heatkiller pro4 full nickle
GPU - EKWB Acrylic FTW3 TI
Pump - EKWB Revo D5 PWM
Radiators - Rad 1 - XSPC 360x45 Rad 2 - EKWB PL 360
Reservoir - Thermaltake 170mm
Temp Sensor - Thermaltake
Hardline Fittings - Thermaltake 16mm
Softline Fittings - EKWB 5/8 compression
Angled Fittings - Dazmode Darkside/Bitspower/Nanoxia
Bulkheads - Thermaltake/Nanoxia
Drain Valve - Dazmode Darkside Pushvalve system
Misc fittings - Dazmode Darkside for a vast majority of them
Tubing - Primarily Dazmode Darkside, But some Thermaltake in the mix.
Cables - Which I make myself!
Sleeving - Mainframe Customs Telios and Dazmode Darkside
Wire - 18awg that I ordered from PC Mods Canada
Connectors - Mainframe Customs and Dazmode (depends on the connector)
Pins - Mainframe Customs
Combs - A mix of Nanoxia CoolForce up front, and Dazmode darkside in the rear.
In the final hours, I actually won a facebook giveaway and got myself some Delta 2 RGB, which I decided I would swap to in the last minutes
Had a bit if dye fallout, which isnt that big of a deal. I didnt throw in anymore lights as it took away from the overall look.
Heres some photos of the final submission.
https://linustechtips.com/topic/1077927-project-50-shades/
Did you take those pics with a gopro?
GAMING PC CPU: AMD 3800X Motherboard: Asus STRIX X570-E GPU: GIGABYTE RTX 3080 GAMING OC RAM: 16GB G.Skill 3600MHz/CL14  PSU: Corsair RM850x Case: NZXT MESHIFY 2 XL DARK TG Cooling: EK Velocity + D5 pump + 360mm rad + 280mm rad Monitor: AOC 27" QHD 144Hz Keyboard: Corsair K70 Mouse: Razer DeathAdder Elite Audio: Bose QC35 II
WHAT MY GF INHERITED CPU: Intel i7-6700K (4.7GHz @ 1.39v) Motherboard: Asus Z170 Pro GPU: Asus GTX 1070 8GB RAM: 32GB Kingston HyperX Fury Hard Drive: WD Black NVMe SSD 512GB Power Supply: XFX PRO 550W  Cooling: Corsair H115i Case: NZXT H700 White
https://linustechtips.com/topic/1077927-project-50-shades/#findComment-12710549
  • 2 weeks later...
Maybe I did, Maybe I didnt. Maybe it was taken with something MUCH WORST.
Some of us dont have expensive camera gear, or a quality phone... because all our money was spent on a computer...
https://linustechtips.com/topic/1077927-project-50-shades/#findComment-12749783
