HELP! I screwed up!
Solved by Sat1600,
1 hour ago, Koxicain said:If not mistaken thats with the feet on.
7mm i can work with im hight, i can cut out some of the foam in the corners for this to work No problem.
But I actually throught i had seen this case and it was too big. But might have been a similar one
According to the manufacturer web page: (W)220mm x(H)472mm x(D)450mm
