the ryzen 7 2700 is much slower in gaming than the i7 7700k. It has twice as many cores but that doesn't help FPS at all.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1077418-ryzen-2700-low-fps/#findComment-12682845
Is there a reason you swapped a 7700k with a 2700x? Ryzen 3000 comes out in a week and will likely be far better in gaming than Ryzen 2000
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1077418-ryzen-2700-low-fps/#findComment-12682855
What speed is your CPU and RAM running?  What are you RAM timings?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1077418-ryzen-2700-low-fps/#findComment-12683058
2 hours ago, MTV119 said:
So I just swapped to a Ryzen 7 2700 from a i7 7700K and ever since I made the swap I have lost a considerable amount of FPS. Is there a reason why and how can I fix this. My GPU is a 1070
Go into MASSIVE AMOUNTS of Detail on your SPECS alone.
We need more info on your setup,...and how its likely setup.
Stock clocked, stock Slower Ram, with even GPU bound games,.. yeah you'll definitely take a decent loss in some/most titles.
Maximums - Asus Z97-K /w i5 4690 Bclk @106.9Mhz * x39 = 4.17Ghz, 8GB of 2600Mhz DDR3,.. Gigabyte GTX970 G1-Gaming @ 1550Mhz
https://linustechtips.com/topic/1077418-ryzen-2700-low-fps/#findComment-12683064
Okay everything is stock. I am running 16 gigs of 3000mhz ddr4 not OC'd at all since I don't even know how to do that. I can't remember my Mobo model but I do know it is a Aorus Pro Wi-Fi. Nvidia 1070. Ryzen 7 2700 and the reason I swapped was my mother board for my 7700k broke and microcenter had a sale going on and it was cheaper for me to swap to a new cpu and motherboard than buy a good motherboard for that chipset. I am a novice if I got any info wrong here I am sorry.
https://linustechtips.com/topic/1077418-ryzen-2700-low-fps/#findComment-12683138
5 minutes ago, MTV119 said:
Stock I'm a novice. I don't really know what I am doing.
Well first thing you need to do when looking for help is to provide as much information as you can.  And details matter.  So what motherboard are you using?  What RAM?  And when I say detail -- I am running an ASUS Crosshair VII with a 2x8GB kit of 3600CL15 RAM with the RAM overclocked to CL14.
Edit:
You answered right before I posted this so ignore it now.
https://linustechtips.com/topic/1077418-ryzen-2700-low-fps/#findComment-12683142
Well first step is to get into your BIOS and setup your RAM with XMP/DOCP.  Sorry I can't remember what Gigabyte calls it.
https://linustechtips.com/topic/1077418-ryzen-2700-low-fps/#findComment-12683145
Ryzen 2700 at stock settings is a bit of a dog, as it tries to stay in the 65w tdp and all-core it hangs around 3.4ghz.
Go into the BIOS and change the multiplier to 40x, do like +.100 mv to the adaptive voltage, enable XMP and increase your dram voltage to like 1.36v, and then it should run a little better and closer to the X version.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1077418-ryzen-2700-low-fps/#findComment-12683253
I've never over clocked before so how do I change the multiplier in here?
https://linustechtips.com/topic/1077418-ryzen-2700-low-fps/#findComment-12683293
this is a slightly different board but it should have the same ideas
https://linustechtips.com/topic/1077418-ryzen-2700-low-fps/#findComment-12683299
