980TI - Temps high at idle
CC268
Just noticed recently that my temps on my 980TI seem to be super high despite there being little to no load. Currently use an NZXT x41 cooler. Any ideas on what might be going on here? Clock speed was at 1139 MHz and dropped down to 135 MHz now...
| Intel i5-6600K | NZXT Kraken X61 | MSI GTX 980TI | NZXT Kraken X41 | ASUS MAXIMUS VIII Hero Corsair Vengeance DDR4-3000 16GB |
                |Samsung 850 EVO 250GB | WD Blue 1TB | EVGA SuperNova G2 850W | Fractal Design Define S |
If it's running that hot under an AIO when it didn't before, then my money would be on the pump died.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
I know I'm thinking the same thing...is there a way to verify if the pump is dead?
I might just put the old original air cooler back on it. I don't use this thing for gaming anyways...
Or it could be the shitty CAM software, it's very common for software to report false readings, that's why i always recommend HWInfo, it's almost compatible with everything
Quote or Tag people so they know that you've replied.
Yea I know CAM sucks lol.
I verified with HWInfo...says the same.
then it's either a bad mount or the pump is dead
Put your ear up against the block/pump and see if you hear anything. If you want to make really sure you could always unplug your CPUs pump and turn off all your fans while you do it, so long as it doesn't take you an eternity to actually do so.
Main rig on profile
VAULT - File Server
