Hello people,
I was recently looking for a GPU upgrade and the RTX 2060 was looking like a good fit for my budget,
but I was wondering which model I should get. I'm really looking for a very cool and quiet model as the card I'm using right now is fairly loud and gets hot.
The price doesn't really matter for what model nor does the size.
Thanks for reading.
PC specs:
I7 8700
1x 8gb Ballistix Elite 3200MHZ
MSI Gaming Trio RTX 2080
G650M PSU
120gb Kingston SSD
3TB of HDD
NZXT S340 elite Black/Red
https://linustechtips.com/topic/1075380-what-model-rtx-2060/
Triple fan Gigabyte or Asus ROG models are extremely quiet. But they're large cards, so make sure you have enough space in your case.
Main system: Ryzen 7 7800X3D / Asus TUF Gaming B650-Plus / G.Skill Trident Z5 NEO 32GB 6000Mhz / Zotac RTX 5090 SOLID OC/ x2 WD_BLACK NS770 2TBs/ Corsair HX1000i/ NZXT H5 Flow
https://linustechtips.com/topic/1075380-what-model-rtx-2060/#findComment-12666456
I have a strix 2060 triple fan and it's never been loud or hot. It is a rather large card tho so make sure you have room in your case. Mine is in a fractal design focus g and i have room to spare
14700k
Thermalright frozen prism 360mm aio
B760 Aorus elite ax ddr5
32gb ddr5 G skill s5 6000mhz CL30
2tb wd black gen 4 nvme
2tb Solidigm P41 plus
2tb seagate hdd
Pny 5070ti
Fractal Ion 2+ 860watt platinum
Thermaltake View 380
AW2725DF 1440p 360hz oled
Aoc Q27G3XMN mini led
Ps5 Pro
Series X
https://linustechtips.com/topic/1075380-what-model-rtx-2060/#findComment-12674549
