I need recommendation with AIO , My List :
1.Cooler Master MasteLiquid ML360R RGB
2.Corsair H100i RGB Platinum
3.Enermax Liqtech II 280/360
Really appreciate if anyone have other AIO Recommendation
also need recommendation for Rads Fans , Im currently Using Corsair LL120 for my chassis fan
so , just use provided rad fans or change rads fan with my fans ?
Thanks ^_^
https://linustechtips.com/topic/1075056-aio-recommendation/
I have no direct experience with any of these, though from experiences of others on this forum, both the Liqtech and the Master Liquid lines are generally considered to be "meh".
Corsair stands behind their products with a stellar warranty, so that's where my vote is going to go.
My recommendations for rad fans isn't likely to change any time soon; NF-F12's or NF-F14's. Genuine Nidec GentleTyphoons, if you can find them for a reasonable price, are excellent as well.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/1075056-aio-recommendation/#findComment-12663963
My recommendations for rad fans isn't likely to change any time soon; NF-F12's or NF-F14's. Genuine Nidec GentlyTyphoons, if you can find them for a reasonable price, are excellent as well.
Okay thanks for the answer
https://linustechtips.com/topic/1075056-aio-recommendation/#findComment-12663970
What cpu, case, and ram are you using? Are you oc'ing?
Where are you shopping / located? Budget?
Is there any particular aesthetic you're aiming for?
The stock fans generally perform fine and there's generally no need to replace them unless you want a different look or lower noise.
https://linustechtips.com/topic/1075056-aio-recommendation/#findComment-12665386
Sorry for the late replies , been busy lately
Spec
RAM : Corsair Vengeance Pro RGB 2x8GB
CPU : AMD Ryzen 5 2600
Case : Fractal Design Meshify C
Im not OC’ing anything on my rig
Im From Indonesia , And always buy pc part from online retailer
My Budget is $180
thanks
https://linustechtips.com/topic/1075056-aio-recommendation/#findComment-12679926
Why not stick with the stock cooler?
https://linustechtips.com/topic/1075056-aio-recommendation/#findComment-12680089
@Zairros17
but why would you buy an overpriced cooler then? Even the 200t Gammaxx by Deepcool mops the floor with stock ryzen 2600 (wraith stealth) cooler.
Get a Gammaxx300 or ID Cooling SE-213V2 and you'll be fine. why would you spend a fortune, when a 20-25USD cooler is a fair improvement in terms of noise and temperatures?
Life is really challenging. I don't always suceed: )
https://linustechtips.com/topic/1075056-aio-recommendation/#findComment-12680139
On 6/29/2019 at 11:01 AM, Vejnemojnen said:
@Zairros17
Actually i change my mind now , want to buy Be Quiet Dark Rock Slim , This cooler is enough right ?
My Stock Cooler died , im borrowing my friends cooler for now , Planning to buy Be Quiet Dark Rock Slim..
https://linustechtips.com/topic/1075056-aio-recommendation/#findComment-12686619
Yeah, it's enough.
Have you tried contacting AMD for a replacement?
https://linustechtips.com/topic/1075056-aio-recommendation/#findComment-12686654
18 hours ago, Zairros17 said:
My Guarantee already ran out , can amd replaced it ? Still have my eyes on Be Quiet Dark Rock Slim.. really like that full black colour hahaha
The DR Slim is very quiet and a great option if that's your highest priority.
https://linustechtips.com/topic/1075056-aio-recommendation/#findComment-12690728
