Elgato HD60 Pro
Go to solution Solved by Jon Jon,
Honestly, a 4C/4T part isn't going to cut it for what you want to do.
I was down this road 3 years ago using my old overclocked i5-3470 to 4ghz and my HD60 Pro.
Fact is, even with the dedicated resources, you still need the compute cycles to run the software as well as game at the same time.
I would suggest trying Relive and skipping OBS for now to see what your performance is like and what you can do.
From there, try offloading OBS to your R9 380X and see if that helps you.
Ultimately, You should be planning to move to an 8C/16T build if you want to get serious with doing this.
Games are getting more demanding, and even with my first gen Ryzen 7, I can bring it to its knees depending on the quality of recording and streaming that I am doing while gaming.
So, long story short my computer isn't powerful enough to run AAA games and record decently with OBS. I have been looking into the Elgato HD60 Pro as it has an onboard encoder in the hope this takes the stress off my CPU (I know I'll have to use Elgato software I'm not too fussed). What I've been reading is it's not possible to transfer data to the capture card and back through the PCI-E card which is why it can't be used 'internally' as such. But what if I use the HDMI out on my GPU and put it straight into the card and then the out into my monitor, would this be feasible?
Also would having an ultrawide-monitor (2560x1080) cause any issues doing it this way or with the capture card in general?
PC Spec:
I5 6600K
R9 380X
16GB DDR3
Thanks in advance for the help guys!!
Ps: I didn't know what category this falls under
https://linustechtips.com/topic/1073293-elgato-hd60-pro/
So you mean to use it like it was made to? The pass through function or to duplicate the video from the gpu is how its supposed to be used.
The pc still has to do the work, encoding with cpu or gpu.
https://linustechtips.com/topic/1073293-elgato-hd60-pro/#findComment-12649649
I thought the HD60 pro has a build in encoder that would do most of the work?
https://linustechtips.com/topic/1073293-elgato-hd60-pro/#findComment-12651615
This should work just fine. And yes the HD60 pro has a built in encoder which means it would handle the process of  processing, compressing and mixing the video and audio (a feature my external HD60s lacks)
AMD HD Relive/ Nvidia Shadowplay are great. Never used relive but Shadowplay has 0 impact on the performance of my GPU when playing games and recording simultaneously (Not sure about streaming though, since I would have to dedicate CPU or GPU power to encoding)
https://linustechtips.com/topic/1073293-elgato-hd60-pro/#findComment-12651636
Desktop:
AMD Ryzen 7 @ 3.9ghz 1.35v w/ Noctua NH-D15 SE AM4 Edition
ASUS STRIX X370-F GAMING Motherboard
ASUS STRIX Radeon RX 5700XT
Corsair Vengeance LPX 16GB (2x 8GB) DDR4 3200
Samsung 960 EVO 500GB NVME
2x4TB Seagate Barracuda HDDs
Corsair RM850X
Be Quiet Silent Base 800
Elgato HD60 Pro
Sceptre C305B-200UN Ultra Wide 2560x1080 200hz Monitor
Logitech G910 Orion Spectrum Keyboard
Logitech G903 Mouse
Oculus Rift CV1 w/ 3 Sensors + Earphones
Laptop:
Acer Nitro 5:
Intel Core I5-8300H
Crucial Ballistix Sport LT 16GB (2x 8GB) DDR4 2666
Geforce GTX 1050ti 4GB
Intel 600p 256GB NVME
Seagate Firecuda 2TB SSHD
Logitech G502 Proteus Spectrum
https://linustechtips.com/topic/1073293-elgato-hd60-pro/#findComment-12652108
