ok so i know its the sensors failing but my moms computer says the cpu is running at -55c.
so just wondering theoretically what would happen if a computer did try and run at remotely those temps, or what is the fail temp of most computer parts
Fan Junkie
https://linustechtips.com/topic/10729-sub-zero-temps/
Maybe not even run? Too cold for the circuit to move?
Corsair 600T White | Gigabyte Z77-UD3H | Intel Core i5-2500k | 8GB Gskill Ares@1600MHz | Gigabyte G1 GTX970 | OCZ ZT 550 | Western Digital Caviar Blue 500GB | Western Digital Caviar Black 1TB | Samsung 840 EVO 250GB (boot) | Full Custom Loop | NZXT HUE
https://linustechtips.com/topic/10729-sub-zero-temps/#findComment-114690
The PC should run fine, pro overclockers that use liquid helium and liquid nitrogen can get their CPU below -100°C as shown here:
The CPU got to reach below -140°C before it shut down. You should be worried only if the CPU sensor mis-reports in higher temperatures causing it to falsely thermally shut down. I'm experiencing this right now with my RIVE, it is reporting 89°C at POST with a correctly mounted liquid cooler.
https://linustechtips.com/topic/10729-sub-zero-temps/#findComment-114761
It would still work, most components can run at super cool temps, like when being cooled by LN2
CPU: AMD 3950x Mobo: MSI B550 RAM: 32GB DDR4 GPU: Asus 3080 Strix PSU: Superflower Leadex 3 720w Case: BeQuiet 500DX
Storage: 2TB SSD + 4TB HDD Audio: SMSL 793ii -> HiFiman HE-400 + Mission MS-50 Speakers
https://linustechtips.com/topic/10729-sub-zero-temps/#findComment-114941
Yes they would indeed run just fine. Personally I have only experienced a sensor reporting back sub zero temperatures once, and that was after the temps had hit 102C and kept rising. Goodbye laptop is all I'm saying. :D If your mothers computer is still running that is not the case in any shape or form though. :)
https://linustechtips.com/topic/10729-sub-zero-temps/#findComment-114950
Although your correct they do drop they temps really low they also only do it for seconds minutes at max before they boot the pc and which point the overclock raises that temp very high very fast and then crashes thus giving only a split second for the screenshot of course that's only suicide clocking but suicide is the only ones that drop it that low of course you are correct and extreme ocs that are benchable are still droped to -50 -80c and closely kept at that level using a blowtorch
https://linustechtips.com/topic/10729-sub-zero-temps/#findComment-115097
I think you need to read up on overclocking mate.
https://linustechtips.com/topic/10729-sub-zero-temps/#findComment-115103
