so I built a new pc and i accidentally put the water cooler the wrong way so the nzxt was the wrong way. i switched it withought fresh thermal paste. i have new stuff coming tomorrow but i cant tell if im thermal throttling or what. when i first booted it everything was fine. i got my things downloaded then i download cinebench run a base test and get around 3800 then i go and do overclocks and get up to 4.150 ghz and 3466 on the memory and get a score around 4200 at around 70c. so i think everything is fine and i go to lower voltage cuz it was on auto. i do that and run cinebench and get a 3200. so i go back fix it back to auto and run cinebech again with an even lower score with higher thermals. so i decide ill order some new paste and remove the overclocked cpu back to normal. i do this run cinebench again and get a 2900 when my original base was 3800. so i just go and play some games. i boot r6s and get into the game then all of a sudden I have what seems to be a 1 second noit milisecond, second response time. i dont know whats happening because i have a great gpu. so i play csgo and i havve around 100 fps at 1080p AND I HAVE A FREAKING VEGA 56 SO WTF.(rainbow 6 was even worse.) i run a whole bunch more tests and cant figure it out. it seems like my cpu is getting worse and worse and ive had it 1 day. i have no overcocks and im just waiting for the noctua thermal paste.
      so after all of that heres the question why are my games running slower than my old i5 7400 1060 3gb build and how can i fix it. do i just need the thermals fixed because im only hitting around 70c on all cores. also i keep crashing in my games so i think my gpu is broken too.
TL;DR: i think my cpu is throttling rainbow has very low fps and 1 full second response time and csgo is at 100 fps.)
specs:
ryzen 7 2700
saphire radeon vega 56
msi pro carbon b450 motherboard
gskill trident z 3600 ram
intel 760p m.2 ssd
sandisk ssd
nzxt kraken x62 rev 2
https://linustechtips.com/topic/1070706-ryzen-7-2700-issue/
If you've removed your overclock then I would reset CMOS and set the memory speed.  Test again.
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1070706-ryzen-7-2700-issue/#findComment-12627513
1 hour ago, c0v3r11 said:
i also found out that my xmp profile isnt sticking and im stuck at 1733 mhz
What 3600 kit do you have?  What is its CAS latency?
https://linustechtips.com/topic/1070706-ryzen-7-2700-issue/#findComment-12627784
Where are you getting that reading, thats half of 3466 so depending on what software you are using to check it will report half of your actual.
https://linustechtips.com/topic/1070706-ryzen-7-2700-issue/#findComment-12627938
2 minutes ago, c0v3r11 said:
ok i realize that with the ram but i still am having weird lag in game only when i move my mouse. also my cpu is on auto for clocks but it is stuck at 3.2 now and wont go off of .9 volts does anyone know how to fix these problems
Did you reset your CMOS?
And you didn't answer the question:  What CAS latency is your RAM kit.
https://linustechtips.com/topic/1070706-ryzen-7-2700-issue/#findComment-12628086
54 minutes ago, c0v3r11 said:
jumper?
Check the manual.  It's three posts with a jumper that you move to clear the CMOS.
https://linustechtips.com/topic/1070706-ryzen-7-2700-issue/#findComment-12628398
