Should i buy 2 250gb 840 evo's and run them in raid 0, or get 1 500gb 840 evo? i cant really decide on what to do so i ask you :D.
CPU: i7 4770k@4.3Ghz GPU: GTX 780ti Motherboard: ROG maximus vi formula PSU: Evga supernova 1000w Platinum
Case: NZXT Switch 810 Memory: g.skill ripjaws X Cooler: Corsair h100i(getting custom loop when i get money next) Storage: Samsung 840 evo 250gb Keyboard: Corsair K95 Mouse: SteelSeries Rival
https://linustechtips.com/topic/107034-what-solution-to-get/
Well 1 500gb is going to be more reliable....
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/107034-what-solution-to-get/#findComment-1430623
I'd say 2 drives in Raid 0, but that's just me.
ha not helping to make decision :P and i know its more reliable
https://linustechtips.com/topic/107034-what-solution-to-get/#findComment-1430636
I would go for the most reliable option, but thats me, you don't really gain much going the other way...
https://linustechtips.com/topic/107034-what-solution-to-get/#findComment-1430650
Get 16 30gb drives, because yolo.
CPU: FX-6300 @ 4.4 ghz GPU: MSI 7950 Motherboard: Asrock 970 Extreme R2  RAM: Teamgroup Elite Black 8GB 1600mhz
Case: Corsair 300r Windowed Storage: 60GB Corsair SSD boot, 1TB WD Black storage PSU: Corsair GS600 Displays: AOC 22", Acer 24" both 1920x1080 60hz
Cooling: Coolermaster V8 cpu cooler Keyboard: QPAD MK50 Cherry MX Blue Mouse: Logitech G500s  Mouse Pad: Corsair MM400 Sound: Sennheiser G4ME ONE headset, Audio Technica ATH M50s
https://linustechtips.com/topic/107034-what-solution-to-get/#findComment-1430651
I would get 1 500GB. Why? Because there is no point in complicating things further with RAID 0. Nothing will use that extra bandwidth. Nothing.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
https://linustechtips.com/topic/107034-what-solution-to-get/#findComment-1430657
It depends on what you're using it for.
https://linustechtips.com/topic/107034-what-solution-to-get/#findComment-1430664
Go for raid 0 and just backup everything.
Pretty simple...
|CPU: Intel 5960X|MOBO:Rampage V Extreme|GPU:EVGA 980Ti SC 2 - Way SLI|RAM:G-Skill 32GB|CASE:900D|PSU:CorsairAX1200i|DISPLAY :Dell U2412M X3|SSD Intel 750 400GB, 2X Samsung 850 Pro|
Peripherals : | MOUSE : Logitech G602 | KEYBOARD: K70 RGB (Cherry MX Brown) | NAS: Synology DS1515+  - WD RED 3TB X 5|ROUTER: AC68U
Sound : | HEADPHONES: Sennheiser HD800 SPEAKERS: B&W CM9 (Front floorstanding) ,  B&W CM Center 2 (Centre) | AV RECEIVER : Denon 3806 | MY X99 BUILD LOG!
https://linustechtips.com/topic/107034-what-solution-to-get/#findComment-1430670
only raid them if you have a dedicated raid card.
No........ Motherboard raid works just fine for two or three drives.
https://linustechtips.com/topic/107034-what-solution-to-get/#findComment-1430671
Raid 0 those bitches! Bitches love raid 0!
haha jk, I'd go for 1 500gb SSD, because I like to wake up everyday, turn on my and start doing my stuff, without having any issue at all, reliable is good if you are not that patient.
If you don't really care and want to feel like you have that amazing super fast PC go ahead and raid!
Motherboards are quite decent with raid 1 and raid 0, it's on Raid 5 and 6 when they are slow and crappy
https://linustechtips.com/topic/107034-what-solution-to-get/#findComment-1430687
I have not issues at all with Raid O. (My 2 1 tb 840 evo's are doing just fine and giving me over 1gb of read and write speeds.)
https://linustechtips.com/topic/107034-what-solution-to-get/#findComment-1430702
well, this has given me a lot to think about. im not sure still hmmmmm
https://linustechtips.com/topic/107034-what-solution-to-get/#findComment-1430703
https://linustechtips.com/topic/107034-what-solution-to-get/#findComment-1430726
I think i will go with the 500gb, i guess i will have more storage anyway.
https://linustechtips.com/topic/107034-what-solution-to-get/#findComment-1430749
Today with the SSDs we have, and much better motherboard controllers data is quite reliable.
But this doesn't mean that we are not adding another point of failure. Everytime you write to the SSD on raid 0, those bits get stripped into two separate devices, it can happen that a write gets done wrong, it's not very likely but it can happen. Unless you don't care about this, most of the times the user is better off by having 1 single drive
https://linustechtips.com/topic/107034-what-solution-to-get/#findComment-1431164
