Hey guys,
I'm going to delid my 8700k today which will also be my first delid ever. I hope that will negate my bad luck in the lottery, since I was unable to hit 5GHz at all, even with 1.375 volts on a 360 AIO.
You can imagine I'm a bit excited.
I watched a couple of tutorials on Youtube so I have a good grasp of what I have to do.
But do you have more tipps for me? Maybe some unusual ones?
My delid gear:
der8auer Delid-Die-Mate 2
Thermal Grizzly Conductonaut
Isopropanol 99,9%
Clear nail polish for isolating the 4 dots near the die
Uhu silicone glue although I don't know if I even will glue the heatspreader back together
My Gaming PC:
Inno3D iChill Black - RTX 4080 - +500 Memory, undervolted Core, 2xCorsair QX120 (push) + 2xInno3D 120mm (pull)
AMD Ryzen 7 7800X3D - NZXT x72
G.SKILL Trident Z @6000MHz CL30 - 2x16GB
Asus Strix X670E-E Gaming
1x500GB Samsung 960 Pro (Windows 11 + 10)
1x2TB Kingston KC3000 (Games)
1x1TB WD Blue SN550 (Programs)
1x1TB Samsung 870 EVO (Programs)
Corsair RM-850X + native 12VHPWR-Cable
Lian Li O11 Vision
Alienware 360 HZ QD-OLED AW2725DF, MSI Optix MAG274QRFDE-QD, BenQ ZOWIE XL2720
Logitech G Pro Wireless Superlight 2
Wooting 60HE
Audeze LCD2-C + FiiO K3
Klipsch RP600-M + Klipsch R-120 SW
My Notebook:
MacBook Pro 16 M1 Pro - 16GB
Proxmox-Cluster:
  • Ryzen 9 3950X, Asus Strix X570E F-Gaming, 4x32GB3200MHz ECC, 2x 512GB NVMe ZFS-Mirror (Boot, Testing-VMs + TrueNAS L2ARC), 2x14TB ZFS-Mirror + 1x3TB (TrueNAS-VM), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i7 8700k delidded undervolted, Gigabyte Z390 UD, 4x16GB 3200MHz, 2x 360GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
  • i5 4670, 3x4GB + 1x8GB 1600MHz, 2x 240GB HDD ZFS-Mirror (Boot), 1x 1TB Samsung 980 Pro NVMe (Ceph-OSD), Dual 10G NIC (Ceph), 2.5G NIC (VMs), 1G NIC (Cluster)
Proxmox-Backup-Server:
  • i5 4670, 4x4GB 1600MHz, 2x2TB ZFS-Mirror, 2,5G NIC
https://linustechtips.com/topic/1069723-my-first-delid/
I can speak from my experience, I have delidded 3 CPUs so far:
1. Don't re-seal it if you don't have to. The space reduction underneath the heat spreader is what gives you the biggest heat decrease.
2. You probably need more force than you think
3. While removing the heat spreader after using the Delid-Die-Mate, be extra careful to not rip off any small parts on the CPU. I destroyed a 600€ CPU because I wasn't careful in the last stage of the delid.
4. Finally, make sure to apply enough liquid metal to the CPU die as well as the heat spreader. Your temps will be awful if the liquid metal layers don't connect properly to each other.
If all goes well, you will have a great overclocker at hand :)
Main Rig: EK custom loop |2700x @ 4.25 Ghz| Msi X470 Gaming Plus | 32gb DDR4 | Aorus GTX 1080ti @ 2088 Mhz | TT Core X71 TG | Samsung 970 Evo Plus 500gb + 256gb Toshiba NVMe + 275GB Crucial m.2
Laptop: Surface Book 2 15" |  i7 8650U 4.2 GHz | 16gb DDR3L | GTX 1060 6gb | 265GB NVMe SSD
https://de.pcpartpicker.com/list/9jvNnH
https://linustechtips.com/topic/1069723-my-first-delid/#findComment-12619293
That's a good one.
Tank you, I hope it goes well :)
My Gaming PC:
Lian Li O11 Vision
Wooting 60HE
My Notebook:
Proxmox-Cluster:
https://linustechtips.com/topic/1069723-my-first-delid/#findComment-12619319
it's not really hard to delid a cpu, just take your time with it :D
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
https://linustechtips.com/topic/1069723-my-first-delid/#findComment-12619426
This.
I did mine without re-seal the IHS. Just hold the IHS inplace firm enough with the stock motherboard intel cpu retention tool. Be very careful when you hold it with your finger while you clipping it on the motherboard.
Here is mine,
My system specs:
CPU: Intel Core i7-8700K, 5GHz Delidded LM || CPU Cooler: Noctua NH-C14S w/ NF-A15 & NF-A14 Chromax fans in push-pull cofiguration || Motherboard: MSI Z370i Gaming Pro Carbon AC || RAM: Corsair Vengeance LPX DDR4 2x8Gb 2666 || GPU: EVGA GTX 1060 6Gb FTW2+ DT || Storage: Samsung 860 Evo M.2 SATA SSD 250Gb, 2x 2.5" HDDs 1Tb & 500Gb || ODD: 9mm Slim DVD RW || PSU: Corsair SF600 80+ Platinum || Case: Cougar QBX + 1x Noctua NF-R8 front intake + 2x Noctua NF-F12 iPPC top exhaust + Cougar stock 92mm DC fan rear exhaust || Monitor: ASUS VG248QE || Keyboard: Ducky One 2 Mini Cherry MX Red || Mouse: Logitech G703 || Audio: Corsair HS70 Wireless || Other: XBox One S Controler
My build logs:
https://linustechtips.com/topic/1069723-my-first-delid/#findComment-12619764
23 minutes ago, _Hustler_One_ said:
This.
Here is mine,
I have always personally used RTV silicon gasket maker. I have tried both and seen no decrease in thermals with it.  I just out a small bead on the edge of the IHS and make sure to leave a gap of about a 1/4" or so on one side.  If you have the die mate just use the relid attachment. If now I just used a foam and clamp setup for about 2-4 hrs to let it set then let the socket hold it down which let's it completely dry over the next few days while you use it.
The benefit to this is that if you do it properly noone can tell it was ever delidded. I mean I have only personally killed one chip and it was a very long time ago. It was the old vise and block of wood/rubber mallet method. Chip went flying and didn't survive. I have used a razor blade for all my delids since.
Btw if you do not use an adhesive you need to move the IHS slightly down from center as it will move up when you clamp the chip down via the locking mechanism.
https://linustechtips.com/topic/1069723-my-first-delid/#findComment-12619827
That's one of my point. I will reseal it when it's the time I will sell it, but before that time is coming I will leave it without resealed, so If I need to reapplied the LM I can do it without any hassle.
My system specs:
My build logs:
https://linustechtips.com/topic/1069723-my-first-delid/#findComment-12619854
So I'm finished.
I went from 4.9GHz 1.325V 84C Cinebench
to 5GHz on 1.35V 66C
and 5.1GHz on 1.425V 79C
5.2 is not possible.
5GHz makes most sense here I think. This huge voltage and temp difference for 100MHz is not really worth it.
My Gaming PC:
Lian Li O11 Vision
Wooting 60HE
My Notebook:
Proxmox-Cluster:
https://linustechtips.com/topic/1069723-my-first-delid/#findComment-12620552
9 hours ago, Noah0302 said:
Hey guys,
My delid gear:
Isopropanol 99,9%
My advice:
reseal with RTV silicone with four VERY TINY DOTS in each corner of the bottom of the IHS.  The smaller the better.
Then you get an easy reseal but without risk of having the IHS elevated higher.  RTV expands as it dries so a tiny dab makes things sealed without any drawbacks :)  You can also even re-delid with your fingers if you messed up the LM application.
https://linustechtips.com/topic/1069723-my-first-delid/#findComment-12620697
