Hi,
i want to build a PC (core-i5, 16gigs of RAM, SSD etc...) and i need GPU that can handle 4k TV´s. It should be in some time 6 of TV´s , but for the start only 3 4k TV´s. Which card can i use. It is not for gaming, only for work (PRTG desktop, Dude, some web pages or pdf´s )
Any advice pls?
https://linustechtips.com/topic/1069382-gpu-advice-for-6x4k-output/
2 minutes ago, Joshcanread said:
you want to run 6 4k displays at the same time on one graphics card?
Do graphics cards even have that many ports? I mean I checked out an ASUS Strix 2080Ti and it only has 4 ports excluding the USB-C
CPU: AMD Ryzen 5 3600  Heatsink: ID-Cooling Frostflow X GPU: Zotac GTX 1060 Mini 6GB RAM: KLEVV Bolt 3600Mhz (2x8GB) Mobo: ASUS B550-F ROG Strix (Wifi)  Case: Fractal Design Meshify C PSU: Deepcool DQ-M-V2L
3 minutes ago, Joshcanread said:
You would have to run 2 cards in sli to get 6 outputs at 4k
Big oof on the wallet
12 minutes ago, Daniel Z. said:
I looked at this card, i would have to reduce the DisplayPort to hdmi, the TV´s have only HDMI ports, but that shouldnt be a problem or?
DP adapts to HDMI basically perfectly, as they are similar enough and both digital.
I just found out that even GTX1050 can handle maximum resolution of 7680x4320 and gigabyte has a model with 3x HDMI, so two of this cards should be fine no?
https://pcpartpicker.com/product/3c7CmG/gigabyte-geforce-gtx-1050-2gb-windforce-oc-video-card-gv-n1050wf2oc-2gd
