i have a Cooler Master HAF X. i would like to replace the rear 120mm out fan with this https://www.ebay.com/itm/upHere-High-Performance-Liquid-CPU-Cooler-120mm-RGB-Radiator-SYNC-Fan-AM4/123763421917?hash=item1cd0dff2dd:g:FJ0AAOSwqB5c1g0r watercooler kit i found on ebay. if i were to get this or something similar, what do i have to do with it? id assume i need to buy the liquid for it, what type would i need e.t.c? i need to buy all parts on ebay. Thanks
If my Response helped you, Please click the Check under my reply, to mark it as The Solution!
https://linustechtips.com/topic/1069083-will-this-watercooler-work-with-my-cpu/
1 minute ago, Saksham said:
i would highly reccommend against buying generic/chinese brand stuff. they will often be low quality and may leak after some time. stick with the well known brands.
thats a cheap chinese one? its from a US seller.
might be a US seller but he probably imported it from china. companies will often ask people in the US to sell products for them so people think its a legit US company but its really just a middleman for the chinese brands.
so your saying its shit and i should get a different one?
this is not something i NEED as i have a be Quiet! Cooler which works fine, ive just always wanted to have some sort of watercooled system and as i figured i was "rebuilding" my pc by putting stupid ass shit in it, i would do this too. if you know of a better one one on ebay for a similar price, please let me know, as well as what i need to do to set it up and install it
I wouldn't use any 120 aio.A air cooler will out cool it.That brand is new to aios i would be scared to use it.And a aio stands for all in one its sealed with coolant in it now.All you gotta do it mount it plug up the fans and pump and let it run.
not saying its shit, just saying it will be unreliable and good air coolers may even be better.
for example the NH-D9L is about 55 and is probably much better and more reliable. probably quiet too because its noctua
Edited by Saksham
