okay so im going to list my specs before anyone ask.
i9 9900k
aorus master z390 gygabyte.
32 gb ram trident z 3000mhz
h115i pro cooler 280mm
evga rtx 2080 ti ftw3 ultra 3 fans
my case is the corsaie 570x
okay so iv been waiting a long time to have a custom loop, and now seeing corsair launching their hydro x series gives me a push forward to get one.
so few questions, i wanna cool only the cpu for now since corsair dont have any gpu blocks for mine yet, i know i might not get any performance wise but its my first time doing a loop and im excited to work on it and looks really fine espcially in my case. my budget is 1k. what things that works to my case? i cant fit anything at the top and only to the front. keep in mind my gpu is beefy so what radiator works to the front and what not?
https://linustechtips.com/topic/1068806-my-first-custom-loop/
Well you can go pretty big on the front as the card isn’t that big. But you would be limited by the top radiator if you do a 240 up there. Need to decide on how much cooling you want first. Then just google the case and see what people are doing.
https://linustechtips.com/topic/1068806-my-first-custom-loop/#findComment-12611795
im thinking of only cooling the cpu now. i dont overclock mainly doing it for the looks.
https://linustechtips.com/topic/1068806-my-first-custom-loop/#findComment-12612273
Have you thought about using the Custom Cooling Configurator on the Corsair site? Just a thought ;) Here a Configuration Code for your setup - dfXFYi
https://linustechtips.com/topic/1068806-my-first-custom-loop/#findComment-12613181
