xfr is kinda like nvidia gpu boost, it pushes clocks higher when there's headroom to do so
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
XFR (Extended Frequency Range) and Sense MI allows the CPU to clock higher when there are resources available, like extra cores, or when the CPU is running at cooler temperatures and lower voltages, etc..
PBO (Precision Boost Overdrive) communicates with XFR (like an assistant to help achieve optimal performance) to basically help it sustain higher boosts for longer periods of time by increasing power limits, and increasing frequency by 25MHz increments, when certain conditions are met, like temperatures.. PBO wont/can't do anything if you're CPU is already being limited by XFR..
Pretty much this.
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
