Would a USB headset work if internal audio was dead?
By
PenguinActually
in Audio
in Audio
Solved by rice guru,
1 hour ago, PenguinActually said:Okay thanks. I wasn't sure if it still had to pass through the internal audio or if it could be processed directly.
if its using USB it becomes it's own audio device as the headset somewhere in line it will have it's own DAC which proccesses the signals so your headphone can make it into sound and AMP which amplifies those signals so what your hearing is loud enough
Featured Topics
Elijah W ·
Posted in New Builds and Planning2 -
MS-DOS ·
Posted in Programs, Apps and Websites1 -
heckboi ·
Posted in Cases and Mods2 -
1
heckboi ·
Posted in Graphics Cards0 -
1
4
7
3
2
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
