I need help...
Go to solution Solved by Guest Kefuren,
Probably the monitor or keyboard I guess cause my headphones are already good now. And this is the monitor http://www.amazon.com/Degree-Ultra-Super-Narrow-VN279QL/dp/B00FE6DNM2/ref=pd_ybh_16
And yes 27 inch 1080p. I sit kinda far away from my monitor so thats OK. http://s1105.photobucket.com/user/wolfman468/library/?sort=3&page=1
If you always sit so far away from your monitor, I would go for the Asus one. And it is an IPS panel, which is good.
OK I have money. I either want to buy A. a 27 inch monitor, B. a mech keyboard (corsair vengeance k70), Or C. New headphones (v-moda m-100)
Right now i have a 22 inch 1080p debranded hp monitor, a stock dell keyboard, and the v-moda crossfade lp's
https://linustechtips.com/topic/106740-i-need-help/
27" 1080p?
I vote for the Keyboard.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/106740-i-need-help/#findComment-1426507
What do you think needs an upgrade the most?
Not knowing more about your setup I'd probably go for the monitor assuming that it'd be an IPS one.
27" 1080p?
https://linustechtips.com/topic/106740-i-need-help/#findComment-1426511
Because right now I have around 250$
https://linustechtips.com/topic/106740-i-need-help/#findComment-1426514
https://linustechtips.com/topic/106740-i-need-help/#findComment-1426519
Its not IPS, its VA, but a good VA
  • Best for work and play with Full HD 1080p visual quality and 178Degree ultra wide viewing angle AMVA+ panel
https://linustechtips.com/topic/106740-i-need-help/#findComment-1426522
Oops, yea I just quickly browsed trough the specs.
Well, the VA panel should be fine too. Maybe not quite as good as IPS, but just for consuming entertainment content and gaming it should be just fine.
https://linustechtips.com/topic/106740-i-need-help/#findComment-1426526
Ok I think ill get the monitor. And it has an awsome stand.
https://linustechtips.com/topic/106740-i-need-help/#findComment-1426533
