Hi everyone!
Just trying to sort out an X299 rig and I'm not sure if something is up with the memory performance, as I'm not really reaching quad channel speeds. I've attached a picture of the User Benchmark score, and it seems to be pretty low for a quad channel setup.
The RAM currently is 4x 16GB 3800Mhz (though I have it set to 3600Mhz in the bios as stability isn't great for some reason). Manually keyed in the timings - 19,19,19,39 and made sure that the voltage is 1.35.
That said, this might be totally normal... but honestly I wouldn't have thought a FAST memory kit in QUAD CHANNEL mode would score 'below potential'.
I've tested the memory bandwidth with a different benchmark tool and it's similar... any thoughts? Motherboard is an Asrock Professional Gaming i9
Cheers!
https://linustechtips.com/topic/1067154-x299-ram-problem/
3 hours ago, Flying Matt said:
Hi everyone!
Cheers!
From what I know of DDR4 overclocking (which isn't much, in my own admission), those timings seem very loose. Maybe try tighter timings?
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
https://linustechtips.com/topic/1067154-x299-ram-problem/#findComment-12597383
It's slotted into the A1 C1 and B1 D1 (what the manual suggests)
With you saying it's normal, the problem is that it doesn't know what RAM I'm using. It's just 4x 16, and if you compare it to the results at 2400mhz for example it actually performs worse.
https://linustechtips.com/topic/1067154-x299-ram-problem/#findComment-12597387
That's what the sticks are rated for, as it's 3800Mhz RAM. Not too loose really for those speeds. 3000Mhz would be down to 15,15,15, for example.
https://linustechtips.com/topic/1067154-x299-ram-problem/#findComment-12597389
Okay then, shows what I know ?
Useful threads:
Total: $1891.98
https://linustechtips.com/topic/1067154-x299-ram-problem/#findComment-12597391
