Hey everyone!
Dont know where to put this but here it is. I have a budget of 1100 including taxes. I am looking for help for which parts i should get. (Including monitor)
Here are my requirements:
16gb ram (8gb if really needed)
SSD and HDD
anothing above a 1060 (Cant be a 1060).
Person who gives me the part list i end up using, will get 30$
Thanks!
EDIT: THANKS FOR THE WONDERFUL suggestions, May I add the monitor needs g- sync. Regardless, I will look into it and message the "winner"
https://linustechtips.com/topic/1065838-need-help/
-Moved to New Builds and Planning-
https://linustechtips.com/topic/1065838-need-help/#findComment-12585056
I don't know what tax is like in your area (I'm assuming you're from the USA?) so this is a list just under 1000 USD for a build (not including peripherals, monitor or Windows?
PCPartPicker Part List
CPU: AMD - Ryzen 5 2600X 3.6 GHz 6-Core Processor  ($159.99 @ Walmart)
Motherboard: Asus - Prime X470-Pro ATX AM4 Motherboard  ($139.89 @ OutletPC)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory  ($89.99 @ Amazon)
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive  ($77.99 @ Amazon)
Storage: Western Digital - Blue 2 TB 3.5" 5400RPM Internal Hard Drive  ($60.99 @ Walmart)
Video Card: Zotac - GeForce GTX 1660 Ti 6 GB GAMING AMP Video Card  ($289.99 @ Amazon)
Case: NZXT - H500 ATX Mid Tower Case  ($69.99 @ Amazon)
Power Supply: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  ($69.89 @ OutletPC)
Total: $958.72
Generated by PCPartPicker 2019-05-21 14:59 EDT-0400
I didn't include a monitor because I don't really know what this system is for.
For a gaming build something like this would be a good option: https://pcpartpicker.com/product/Br8j4D/acer-kg241-pbmidpx-240-1920x1080-144-hz-monitor-umfx1aap01
But I wouldn't recommend that for a photo or video editing build.
Intel would of course also be an option for this build and might even be a better option if you were to game on 144Hz.
Something like a 9400F system for example.
But as I said, I don't know what sales tax is where you live, so that build + monitor would put you over the 1100 USD mark. To cut down cost you could probably get a simpler board, no HDD (it's not really needed), maybe get a simpler case and with the monitor there's also some stuff possible..
Those savings could probably net you a build about 150 USD less that what I have listed above.
https://linustechtips.com/topic/1065838-need-help/#findComment-12585097
52 minutes ago, NewToBuilding said:
Hey everyone!
SSD and HDD
Thanks!
Without knowing your location, shipping and tax rates it is impossible to make recommendations. Post a pre tax and shipping budget. Knowing how the system will be used would also be helpful. Keep the $30, your system will need it.
https://linustechtips.com/topic/1065838-need-help/#findComment-12585218
2 minutes ago, ManosMax13 said:
What components are poor?
Locked cpu for starters with a Z390 chipset.
The cooler is overpriced for a locked cpu. You don't need to be spending nearly $60 on that.
Motherboard is pretty crap considering you can get a Gigabyte Z390 UD for less.
You can probably save $40 on the ram by not getting RGB.
Hard drive could be better i.e Seagate Barracuda or WD Blue etc. That one looks like an older Toshiba model.
A 120GB SSD is way too small considering you can get a 250GB+ for not much more.
The psu is pretty crap as well.
https://linustechtips.com/topic/1065838-need-help/#findComment-12585234
Ok sorry i see let me do a fix real quik
https://linustechtips.com/topic/1065838-need-help/#findComment-12585242
How about now?https://pcpartpicker.com/list/H8vN8Y
https://linustechtips.com/topic/1065838-need-help/#findComment-12585267
There's a good reason for that. Z390 will allow RAM speeds of 3000MHz+. There are titles which show up to a 16% improvement in FPS going from 2666MHz (which is what the B-boards are locked to) to 3000MHz. It also will allow a real upgrade path to the 9700K and the 9900K, whereas the B-boards all have far weaker VRMs, cutting off any upgrade path.
The UD is only $20 more than the B365 boards. It's definitely worth it for the RAM speed boost and the upgrade path.
https://linustechtips.com/topic/1065838-need-help/#findComment-12585444
Here's my build. I fit in a 2070:
EDIT: I just realized a monitor was a part of the requirements, so here's a similar adjusted build:
Both build sport the 9400F, an excellent gaming chip, 16GB of RAM, an A+ tier 80+ Gold PSU, and a dual fan RTX 2060/70. Neither build includes a CPU cooler because the cooler that comes with the 9400F is sufficient in terms of cooling capacity. The only thing is it's louder than aftermarket solutions. I'd say give it a try with the stock fan, and if the noise does get to you, you can always get an Arctic 34 Esports ONE cooler for $30.
https://linustechtips.com/topic/1065838-need-help/#findComment-12585460
Is there any actual data that supports the fps improvement with a locked cpu and faster memory? If so a link would be useful.
https://linustechtips.com/topic/1065838-need-help/#findComment-12585482
Yeah, it's here:
See The Division 2 for the quoted 16% gains. Also note that the 9400F doesn't scale much at all beyond 3000MHz, so those 3400MHz results are very comparable to 3000MHz.
https://linustechtips.com/topic/1065838-need-help/#findComment-12585487
I did state that the Gigabyte board was a better buy. If it was me I would probably go Ryzen and hope that they nail it with the 3000/4000 series cpu's. We need some competition for 1080p 144Hz instead of just Intel suggestions all the time.
https://linustechtips.com/topic/1065838-need-help/#findComment-12585663
