Ethernet over Coax?
Solved by Donut417,
3 hours ago, Azriel said:So I have DirecTV and this is how the router/modem is set up. I can't run an ethernet cable to my room, so I was wondering if there was a way if I could use ethernet over coaxial with the outlet in my room. I was looking at this but I was wondering if it was a good option. I'll take any idea you guys have. Wireless really isn't cutting it
Looks like you have DSL. As long as thats the case, then Deca adapters should work. Though I think they are limited to 100 Mbps.
