Corsair fan screws
Peiguy
I've recently put together my first PC in the Spec-04 and I tried installing Corsair's ML fans realized that the screws included don't fit the screw holes in the case as they're too skinny, does anyone know the dimensions or what kind of screws this case uses because I can't figure it out
Case:https://www.amazon.com/CORSAIR-Carbide-SPEC-04-Mid-Tower-Tempered/dp/B074VN8HNM/ref=sr_1_fkmr1_1?keywords=spec+04+tgt&qid=1558235946&s=gateway&sr=8-1-fkmr1
Feel free to ask any questions, thank you!
Those aren't threaded holes.. Nothing came with screws that look like these? These are what you use to screw the fans in when there are no threads available.. You stick it right in the hole and force screw it into the fans mounting hole.
Ryzen 3800X + MEG ACE w/ Radeon VII + 3733 c14 Trident Z RGB in a Custom Loop powered by Seasonic Prime Ultra Titanium
PSU Tier List | Motherboard Tier List | My Build
My case didn't come with anything except the fan, it was supposed to come with an accessory's kit such as screws and zip ties and HDD mounts but it didn't come with either
My fans came with screws that look like that but they're not thick enough to actually screw into the hole
You should have contacted store about that one. Its clearly packaging issue from factory and enough for RMA.
Pic of screws? Fans usually use what is called self-tapping screws. They are just thing enough to go straight through case fan holes and thich enough so that they screw into fan plastic.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
They look like this but have a small notch
Those are correct screws. They aren't suppose to be tight on case, as they will tap into fan itself.
But the problem with them is that they're not long enough to screw into my case
You are supposed to put screw in from outside of the case. Just look at how pre-installed fans are.
Ooooooooooooohhhhhhhhhhhhhhhhhhhhhh...that actually makes sense, why am I so dumb? Thank you!
