So recently I got a RTX 2080 TI as a gift (don't ask) and was wondering if I need to upgrade. Currently I have a i5 7600k, gtx 1060 6gb, and a 1080p 144hz monitor. Should I go ahead and put the 2080 TI in my system or should I upgrade first? If I  upgrade should I upgrade my CPU or monitor as I only have the cash for one currently.
https://linustechtips.com/topic/1065028-2080-ti-help/
def don't need to upgrade the monitor unless you are looking to improve imagine quality, but upgrading from a 7600k to a 7700k is a bit wasteful, wait for zen 2 imho.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1065028-2080-ti-help/#findComment-12577647
Just pop the 2080 ti in your system! It's, graphically, a pretty solid upgrade from your 1060, and with your 144 hz monitor you'll probably be able to used that extra available performance. Only upgrade your monitor when you actually want something better/different, don't upgrade it for the sake of "I can upgrade/my GPU "could" handle more". :) Run task manager or whatever to see if you are being bottlenecked by your CPU while gaming/doing whatever, and only upgrade if you actually see a bottleneck, otherwise, you're just fine right now (which I expect to be the case). :) Generally, if your GPU runs at 100% during games and you're not stuttering or so, it should (!) be the GPU that is still the bottleneck in that specific scenario.
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
https://linustechtips.com/topic/1065028-2080-ti-help/#findComment-12577674
Thank you
https://linustechtips.com/topic/1065028-2080-ti-help/#findComment-12577688
Just because your CPU will bottleneck the 2080 Ti it doesn't mean you experience won't be better with it.
I would be more worried with your PSU being enough for a 2080 Ti...
Personal Desktop":
Luna, the temporary Desktop:
https://linustechtips.com/topic/1065028-2080-ti-help/#findComment-12577700
Had a 500w but I just purchased a EVGA supernova 750w G3 a few days ago because I know I needed a better one
https://linustechtips.com/topic/1065028-2080-ti-help/#findComment-12577800
