Try running DDU before installing new drivers. This will wipe any left overs of the current Nvidia drivers.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1064712-help/#findComment-12575278
14 minutes ago, TCG_Infiniti said:
I just bought a Red Devil RX 570 to replace my MSI 1050ti and after deleting all Nvidia drivers I get a blue screen every time I install new drivers.  The error code is atikmdag.sys  HELP!!!
https://www.majorgeeks.com/mg/getmirror/display_driver_uninstaller,1.html
Run that ^ in safe mode, let it remove all remnants of nvidia drivers, then re install AMD drivers.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/1064712-help/#findComment-12575285
6 hours ago, Wing_Assault said:
Why did you buy a rx 570 to replace a 1050Ti? They both have similar performance. In my opinion, you should have waited for Navi or just buy a 1070 or 2060
50% better performance is an upgrade to me, especially since the card is really cheap right now.
17 hours ago, TCG_Infiniti said:
Awesome!  I'm running it right now.  Ill comment if it worked. :)  Thanks!!!
Is it 2nd hand unit?
https://linustechtips.com/topic/1064712-help/#findComment-12576677
