So i have an old computer that was just lying around, doing nothing and i got bored and wanted to try and make a FTP server with it. I put Xubuntu, because normal ubuntu is too laggy and it just breaks it. I have got it set up so it works with file explorer in windows, but i want it to display the amount of storage it has, and has left, you know, like it does when you plug a USB stick in, or with  your internal HDD/SSD, as shown in the picture that is hopefully going to attach if i can remember. As you can see in the image, the server does not show the blue bar thing and or the storage.
Issue #2:
When i try and view say, a video or picture off the server, it re-downloads it onto the device, is there anyway i can get it to just stream to the device?
https://linustechtips.com/topic/1064102-xubuntu-ftp-lan-server-help/
Why not just create a CIFS share since its on LAN? its far more user friendly than FTP and more secure (since i assume you arent doing SFTP)
Quote
Literally the only difference between Xubuntu and Ubuntu is the XDesktop environment. It uses the Gnome IDE vs XFCE. Not sure why it would be laggy of breaking
Quote
FTP doesnt do that
Quote
Issue #2:
No, because FTP doesn't do that. It is only a file transfer.
In summary - set up a SMB/CIFS share.
Heres how to do it from the GUI, i imagine its similar for the latest versions: http://ubuntuhandbook.org/index.php/2015/02/share-a-folder-in-ubuntu-14-04/
They have this tutorial as well which uses the terminal: https://tutorials.ubuntu.com/tutorial/install-and-configure-samba#1
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
If you want a dead simple setup consider using Turnkey. Just grab the ISO and install it like any other OS. Has sensible defaults and can be configured from a GUI.
https://www.turnkeylinux.org/fileserver
Intel 11700K - Gigabyte 3080 Ti- Gigabyte Z590 Aorus Pro - Sabrent Rocket NVME - Corsair 16GB DDR4
