So I bought a MSI Gaming X RX 480 second hand. It had been used for mining. When I plug it into my system (i5 3570, GA B75M D3H) the lights turn on and the fans spin up, but the monitor (the monitor works, I tested) doesn't detect a display. When I take the GPU out and use the integrated graphics everything is fine. I can test it using another system, but do you guys think it's broken? Or do you think that it still is set up for mining and that's why there is no video output? Can you tell me how to make sure?
https://linustechtips.com/topic/1063969-help-please/
Which PSU do you have and have you plugged the power connector to the GPU?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1063969-help-please/#findComment-12568069
Just now, Mr_Argon said:
I just got the PSU, but it's second hand. It was working in perfect condition according to the old owner though
i'm a bit skeptical about second hand psu's in general, tho it's an okay-ish psu
do you have any other gpu on hand? or integrated graphics?
https://linustechtips.com/topic/1063969-help-please/#findComment-12568092
1 minute ago, Oalei said:
Nononononnonoonnonoonoonnonoononononononononoononononononononon,  never buy a used PSU ever.
I asked on this forum multiple times and everyone said it was fine. Also it works.
https://linustechtips.com/topic/1063969-help-please/#findComment-12568098
3 minutes ago, LukeSavenije said:
then I'm surprised you haven't been visited by @Stefan Payne...
2 minutes ago, Oalei said:
Every PSU works and every PSU have it's own problem, used PSU is like you're trying to waste money or even burn down the house.
Guys this isn't about the PSU. Can I please get told how to get the proper BIOS onto the GPU? If I have problems with my PSU, then that's my fault, but right now I'm trying to get my GPU working
https://linustechtips.com/topic/1063969-help-please/#findComment-12568108
15 minutes ago, Mr_Argon said:
I tried swapping it, still nothing
When you have the card installed but use the integrated Intel for output, is the 480 detected when you enter Windows?
https://linustechtips.com/topic/1063969-help-please/#findComment-12568119
I can't use the integrated graphics when the card is plugged in. I have to take out the card for the integrated to work
https://linustechtips.com/topic/1063969-help-please/#findComment-12568124
Are you sure about that? (although the BIOS is set to use the integrated graphics first)
To be able to try flashing a non-working card you have to be able to boot off a second card or an integrated GPU.
https://linustechtips.com/topic/1063969-help-please/#findComment-12568131
Yeah, I'll try again, but I'm not too hopeful. I do have another GPU, and that one does work (Sapphire RX 460) but my motherboard only has one x16 slot, I'm pretty sure that the other one is a x4.
https://linustechtips.com/topic/1063969-help-please/#findComment-12568142
I just retested, it doesn't output a display from the integrated graphics when the GPU is turned on
https://linustechtips.com/topic/1063969-help-please/#findComment-12568158
