8 minutes ago, Wh0_Am_1 said:
The bottom one is USB 3.0, the top I am pretty sure is a fan cable
top cable has a phanteks RGB connector from the looks of it, no way is that a fan cable,
top cable wither gets plugged into another phanteks RGB cable if you have more to plug in, or to one of their rgb 5050 adaptor cables.
Just now, icedwater said:
am i going to NEED this cable or no?
it's only for your shiny RGB, not needed.
My mistake
In search of the future, new tech, and exploring the universe! All under the cover of anonymity!
2 hours ago, icedwater said:
I have no idea where or what this header does (refer to picture below). Its labelled main. SORRY if its stupid. im pretty new
The Blue cable is for usb and it provides a faster speed as it connects to a special faster port...
the first image looks like a mail and female fan headers judging by the 4 metal pint ( by the way  when a fan has 4 pins it means that its fan curve can be controlled by the user in bios or elsewhere. Thats important cause a lot of fans come with just 3 pins. 3 pins meaning the fan curve only be controlled by give it more electricity to bust up the speed of it and it will stay like that at all times. 4 pins is ideal.... you can controll the speed  is what I am saying ...
anyways hope that helps it anyway ..
Screwdriver specs: Long, pointy. Turns things. Some kind of metal.
Main rig:
i9-7900x | Asus X299-Prime | 4x8GB G-Skill TridentZ @3300MHz | Samsung 970 Evo 500GB | Intel 5400S 1TB | Corsair HX1200
unRAID server:
Xeon  E5-1630v4 |  Asus X99-E WS | 4x8GB G-Skill DDR4 @2400MHz | Samsung 960 EVO 250GB cache drive | 12TB spinning rust | Corsair RM750X
FreeNAS server:
AMD something-or-other | Asus prebuilt sadness | 8GB DDR3-1600 | 9TB magnetic storage | Potential fire threat
HTPC:
i7-4790 | GTX1650 | Dell Sadness | 12GB DDR3-1600 | Samsung 860 250GB | 1TB magnetic storage | James Loudspeaker SPL3 x2 | Corsair SF450
2 hours ago, max668 said:
3 pins meaning the fan curve can not be controlled at all
All new boards have a DC mode, you can adjust a curve as well as PWM
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
1 hour ago, max668 said:
yea but as I remember you cant control 3 pin fans in a software. Is that correct ?
Ye, you can, FanExpert, MSI  dragon center do it very well, those i have use,
There must be for the other brands but i don't know them
9 minutes ago, veryDIMM said:
The top cable is a PWM fan extender. the bottom one is a usb 3.0 header.
It's not a fan connector. It has different keying on the plastic surround- I assume so you don't do something silly like try to plug your 3-4 pin fans into it.
It's an RGB connector as already advised by Herman
You can control 3 pin fans. The difference is that 3 pin fans you control the voltage, where 4 pin (PWM) fans you control the pulses
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
" 3 pins. 3 pins meaning the fan curve only be controlled by give it more electricity to bust up the speed of it and it will stay like that at all times."
Thats exactly what I said ...^
Well the answer then is yes, you can control 3 pin fans via Software as long as the motherboard supports sending variable voltage to the fan header which is every board ive ever used in the last 10 years basically.
what I was trying to say is that they differ from 4 pin and they are not controlled the same way. I have tried setting a curve for my 3 pin fans and, from the research I have done I was told you cant you can only set voltage up and down. That is the point I was trying to make :)
